    Need an example to munipulate a dynamic component with ruby
    9 Posts 5 Posters 2.4k Views 5 Watching
    • S
      shirazbj
      After open a SKP file containing a dynamic component, I'd like to try to change the component options by ruby code. And place another instance.
      Is it possible to do these under SU free version?
      • H
        HPW
        I am also interested in this question.
        Furthermore I would like to know if it is possible to create a dynamic component at runtime with ruby code?
        Or change it (Not only an option)?
        • H
          HPW
          Found some answers here:
          http://groups.google.com/group/sketchupruby/browse_frm/thread/eb7d2e7ab9038492/af73a7ee457b82df
          • R
            remus
            If you send scottliniger a PM he might be able to knock up some example code, i know he's certainly talked about manipulating DCs with ruby before.
            • S
              shirazbj
              Thanks HPW.
              The link you provided was last posted on Nov 25 2008.
              I tried the code there. The skp files under "Components/Components sampler/" folder seem to be only a simple component or include dynamic component but no option.
              I added an instance of an DC with option in that way, when i right click to try to change the option, I was told there is no option.
              • scottliningerS
                scottlininger
                Hey guys,
                Here's the "quick and dirty" overview of how to apply some options and then fire a redraw of a DC.
                I'm working (slowly) on some better documentation. In the meantime, you can kind of understand how the various attributes work by inspecting the "dynamic_attributes" library yourself. This tool is handy for looking at attributes.
                I just posted a tutorial on reading DC attributes to the code site. That could be helpful, too. πŸ˜„
                UI.menu("Plugins").add_item('Make Sang Red') {
                  # Assumes that sang is the 1st entity in model.
                  sang = Sketchup.active_model.entities[0]
                  sang_def = sang.definition
                  # Override sang's shirt color to red. ("material"
                  # is a special attribute that requires
                  # you to set a formula to "take control"
                  # over the default material the user has painted.)
                  sang_def.set_attribute 'dynamic_attributes',
                    'material', 'red'
                    '_material_formula', '"red"'
                  # Add a new configurable option to Sang.
                  # (Any attribute that starts with an underscore
                  # is a "meta attribute" that describes behavior.)
                    'weight', '145'
                    '_weight_label', 'weight'
                    '_weight_formlabel', 'My Weight'
                    '_weight_units', 'STRING'
                    '_weight_access', 'TEXTBOX'
                  # Change the description that shows
                  # up in the configure box with a custom
                  # formula.
                    '_description_formula',
                    '"Sang is now red and weighs " & weight'
                  # There is a global handle into the plugin that
                  # allows you to make the same calls that the
                  # plugin does, like so...
                  dcs = $dc_observers.get_latest_class
                  dcs.redraw_with_undo(sang)
                Let me know what doesn't make sense. πŸ˜‰
                • Scott Lininger
                  SketchUp Software Engineer
                  Have you visited the Ruby API Docs?
                • Chris FullmerC
                  ooh, I'm excited to check that out, thanks Scott!
                  Chris
                  All my Plugins I've written
                  • S
                    shirazbj
                    Thanks Scott. That's fantastic.
                    After try your code, I saved red Sang with weight option as a "red sang.skp" under folder "Components/Components Sampler/"
                    Then I tried to load this skp file like this:
                    def red_sang
                    path1=Sketchup.find_support_file "red Sang.skp" ,"Components/Components Sampler/"
                    model=Sketchup.active_model
                    definitions = model.definitions
                    componentdefinition1 = definitions.load path1
                    point = Geom::Point3d.new 10,0,0
                    transform = Geom::Transformation.new point
                    instance=model.entities.add_instance componentdefinition1,transform
                    UI.menu("Plugins").add_separator
                    UI.menu("Plugins").add_item("Draw red sang") { red_sang }
                    But when I check the option, there is no option anymore.
                    Should I load the file in other way?
                    • scottliningerS
                      scottlininger
                      When you saved redsang.skp, did you File > Save As, or did you Right click > Save as?
                      The File > Save As method is probably what happened. This isn't the same as saving sang as a standalone SKP. Try right clicking on red sang and "Save as" and then try the import. See if that works. πŸ˜„
                      • Scott Lininger
