    Some plugin changed my MOVE command
    3 Posts 2 Posters 304 Views 2 Watching
    • mitcorbM Offline
      mitcorb
      Hello,
      Recently, I have installed several plugins from this forum.
      Among them is EventRelay, FollowMe and Keep, and Protrude.
      At some point, my Move command has changed to a default M+(Copy) command. This isn't necessarily bad, but now I have to hit control to turn off the + if all I want to do is move.
      I wonder if anyone else is seeing this.
      mitcorb
      ps As usual, moderator please move this post if it is misplaced.
        Jim
        Plugins can't change your shortcuts. EventRelay, however intercepts your key presses before passing them along to SketchUp.
        I think EventRelay is configurable, so you might be able to get the desired behavior that way. If all else fails, removing EventRelay should take care of it.
        • mitcorbM Offline
          mitcorb
          Thanks, Jim:
          I will check this out.
          EventRelay also appears to pop up the Ruby console when I start Sketchup 6. I usually just click it off, as I have not had time to really utilize the plugin.
          mitcorb
          ps I hope you were able to contact ArchitectBoy, ref: skin.
