    Function: toggle toolbar
    6 Posts 2 Posters 885 Views 2 Watching
      Malkomitch
      Hello there
      For the project i'm coding on these days, i need to create a command, on a toolbar, which toggle another toolbar.
      The method get_last_state from the class Toolbar looks convenient for that but i noticed a strange behaviour.
      Here is my code for defining my toolbar and the function that toggle the other toolbars.
      #here is the function for toggling my toolbar
      def toggle(toolbar)
         toolbar.show if toolbar.get_last_state == -1
         toolbar.show if toolbar.get_last_state == 0
         toolbar.hide if toolbar.get_last_state == 1
      #and then, the block defining my toolbars
      main_tb= UI;;Toolbar.new("main toolbar")
      cmd= UI;;Command.new("Toggle the second toolbar"){toggle(second_tb)}
      cmd.large_icon = cmd.small_icon = File.join(path_to, "maintb.png")
      cmd.tooltip = cmd.status_bar_text= "Toggle the second toolbar"
      main_tb.add_item cmd
      main_tb.show
      main_tb= UI;;Toolbar.new("my toolbar")
      second_tb= UI;;Toolbar.new("second toolbar")
      cmd= UI;;Command.new("hello"){UI.Messagebox("hello")}
      cmd.large_icon = cmd.small_icon = File.join(path_to, "secondtb.png")
      cmd.tooltip = cmd.status_bar_text= "hello"
      second_tb.add_item cmd
      But this code works for showing, not for hiding...
      hu??
      so i checked manually the method get_last_state directly in Sketchup, using the ruby console
      I noticed that the value returned by get_last_state never change, whatever i do with show and hide
      #<UI;;Toolbar;0x4b22d08>
      cmd= UI;;Command.new("my cmd"){UI.Messagebox("hello")}
      #<UI;;Command;0x4b22ae0>
      tb.add_item cmd
      tb.get_last_state
      -1
      tb.show
      nil
      tb.get_last_state
      -1
      tb.hide
      nil
      tb.get_last_state
      -1
      is there a problem with this method?
      did i miss something?
      thank you for your time
      • Chris FullmerC Offline
        You could try using toolbar.visible? instead. That gave accurate results for me when I tested it manually.
        Chris
        All my Plugins I've written
          tb.add_item cmd
          if tb.visible?
           tb.hide
          else
           tb.show
          That works for me. I'm running it in the webconsole by Jim (thanks again Jim) which is much more useful than the ruby console for little snippets of code.
          When I put that into the console, it all works swimmingly well. Toolbar on and off 😄
          Chris
          Edit: I like this idea. It gives me ideas. I might use something like this in future scripts.
            Malkomitch
            Thank you Chris.
            I'll check that when i'll get back to work next monday.
            it's such a fast answer to my very first post here.
            This forum looks nice for sharing knowledge and ideas !
              Malkomitch
              It works!
              Thank you again!
                Woohoo! That might be my first correct response in this forum 😄 I'm glad it helped,
                Chris
