    Req: Scale group of items around each center
    12 Posts 5 Posters 989 Views 5 Watching
    • PixeroP Offline
      Pixero
      Im having some trouble with scaling a bunch of components (trees).
      It scales around the total selections center which results in the placement "beeing scaled" as well.
      Is there a way of scaling based on each selected components center?
        remus
        If You want to scale all the similar components: enter the component->select all->scale+ctrl.
        • PixeroP Offline
          Pixero
          No that is not what I want.
          I have several different components that I want to scale based on each components center.
          In other words, rescaling but keeping their individual placement.
          • Chris FullmerC Offline
            I see, a plugin where you could select 20 components, all different componeonts, or some the same, or whatever. But have them all selected and then specify a scale and they all get scaled by that factor. So 0.5 makes them all .5 times smaller, etc.
            Should they scale around their axis or actually around their centerpoint?
            Chris
            All my Plugins I've written
              ok, I have a working version that gives an input for scale around center and its working well. I'll add a scale around axis function too, since that is often what I need (for people and trees and things that have a base point that should always stay in the same place). Once I get that implmeneted and get it writeen into the menu system, I'll post it.
              Chris
              • PixeroP Offline
                Pixero
                Wow, thanks in advance. πŸ˜„
                Would it be difficult to add a choice for random scale with a min and max value as well?
                (As in: Scale randomly between 85% and 115%.)
                And if I could dream a choice for random rotation around z axis... πŸ˜‰
                  πŸ˜„, we'll see. I'm strugling with the scale on axis function - can't find the axis. I'll go ask in another thread. Otherwise its coming along very well.
                  Chris
                    Ok, its done. I think you'll like it!
                    Chris
                      Where is it? πŸ˜‰
                      • X Offline
                        xrok1
                        Chris, did you see this: http://groups.google.com/group/sketchupruby/msg/caaf0e9554881c5a
                        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                          Here it is.
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17507
                          And thanks for the link xrok, I found a similar post by Chris here on the forum. Fortunately I did not need any of that. I'm not try to change axis locations, merely pinpoint the axis in 3d space. Which I did figure out and its posted in another thread. Thanks.
                          And I did get it to scale from centerpoint, world axis (0,0,0) and from the component axis. And I also included a random scale feature.
                          Chris
                          • PixeroP Offline
                            Pixero
                            Big thanks. Will test it now. πŸ‘
