    [Plugin] SketchUp Animation using mover.rb
    37 Posts 22 Posters 80.0k Views 22 Watching
    • FletchF Offline
      Fletch
      Thanks Jim,
      That's a good place to start πŸ˜‰ (either animating something, or trying to code a fix for it.)
      Fletch
      3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
        Have you made an exportation animation "Avi" with Mover?
        Not by the Twilight Render (this is working fine) πŸ˜‰, but from directly Sketchup Export ? (with no render)
        • P Offline
          pirun14
            Cool tutorial β˜€
            Seems you have not use scene 3 and don't make Update Scene β˜€
            • P Offline
              pirun14
              Cool tutorial β˜€
              Thanks.sorry,i have over scene πŸ˜‰
                skkor9y
                year b4 i used this plugin, but it had a different name TRANSFORM.rb
                  Jim
                  Didier Bur wrote one in 2005 - mover and proper animation use the same technique as Didier.
                  http://www.crai.archi.fr/RubyLibraryDepot/Ruby/transformer_beta.rb
                    Speaker
                    great plugin πŸ‘ . It's a pity it doesn't work with v-ray 😞
                    http://www.youtube.com/user/latvietis1234
                    • W Offline
                      wyatt
                      Has anyone played with this plug-in more? I can set the scenes so that elements move properly between scenes, but when I export as avi nothing moves. Does the plug-in not support exporting, or is there something else I should be doing? Would a different animation plug-in work better?
                        @ Wyatt
                        I believe that you must record your screen with another prog during the Mover's animation πŸ˜‰
                        • P Offline
                          Pout
                          This is a know problem with sketchup animation.
                          All none-sketchup scripts are neglected in the creation of the animation.
                          • O Offline
                            Oli3000
                            Hi all,
                            I wondered if you could help me solve a strange issue!
                            I am trying to animate a group of concentric cylinders that scale around their centre point. However, even with the scale definition fix I still get strange results.
                            If I use scale definition it doesn't change size, it just stays at the new scaled size the entire time. If I don't then it does the move animation, then jumps to the scaled size. There is no animation of the actual scaling.
                            What am I doing wrong? I looked at doing the make unique feature, but they are always greyed out.
                            Thanks in advance!
                              Seems like Proper animation by Morisdov πŸ˜‰
                              Seems a little more easy for select a position but you must go to the scene itself ! β˜€
                              Else you can use the Set Transition Times by Morisdov with mover.rv πŸ˜‰
                              • E Offline
                                erdenebilegara
                                ara
                                it works, now i am gonna to make a cartoon, THANKS
                                • G Offline
                                  glro
                                  @oli3000 said:
                                  Hi all,
                                  Thanks in advance!
                                  i also noticed unwanted displacements of some components or groups; to avoid that, i group the component that moves strangely, with another one that doesn't.
                                  if the movement comes from a scale, it is not possible, obviously...
                                  anyway... as i use the plugin from time to time, i added 2 features:
                                  packaged as a rbz file, so it is possible to avoid loading it it when you don't need it, through windows>extension> ... untick the box in front of "cmd_mover"
                                  added a line in the right clic menu to save the current position of the selection, so you don't need to open the folding menu above the screen
                                  I hope it will be usefulplugin mover
                                  • majidM Offline
                                    majid
                                    This has been a great animation plugin and one of my favorite for a loong time.! thanks for update!
                                      Time saver! πŸ‘
                                      • 2 / 2
