    Animation of objects between scenes
    4 Posts 4 Posters 614 Views 4 Watching
    • D
      DCEMaine
      Just had a thought while reading yet another forum post describing how to create multiple objects and change visibility in scenes and all that.. It's obviously a brute force approach.
      Then I had a thought.. I recently grabbed the FlightPath script. Even though I haven't used it yet, I get the idea.. i.e. make a sequence of lines/curves that the camera will follow...
      Is there an 'OnSceneChange' notification in the API? I'm thinking (frankly without thinking through it very much) that a similar thing could be done with an object.. no? specify a path, an object and do a move command along the path on scene change..
      Is this way off, or is there something to it? As I said, this was just a flash thought as I was perusing..
      • M
        morisdov
        404 Not Found
        (www.ohyeahcad.com)
        • E
          Ecuadorian
          http://www.pushpullbar.com/forums/ruby-scripts/9467-visual-index-ruby-scripts-2.html#post131749
          -Miguel Lescano
          • J
            Jim
            proper animation does just that, although the movement between scenes is linear and can not use a defined path. It's still a fantastic extension.
            Error 404 (Not Found)!!1
            (morisdov.googlepages.com)
