    [Plugin]SketchyPhysics3 beta.
    69 Posts 14 Posters 27.2k Views 14 Watching
      CPhillips
      Could you try one more time. But this time open the Window->Ruby Console before you try to connect them. Then cut and paste any text after it fails.
      Thanks!
      • P Offline
        phy
        @l.frisken said:
        mine does that but it refuses to connect. Very strange 😢
        Try clicking on the sphere and then ctrl clicking on the joint. That's how I've always connected joints.
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          l.frisken
          ok, will try cphillips.
          phy, I have tried that, and it works fine with sp2 but not with sp3 for me
            l.frisken
            this is the ruby script from creating the joint, grouping it with he rectangular prism, and then attempting to connect it:
            First click
            potentialParent #<Sketchup;;Group;0x86b5238>
            onSelectionAdded
            onSelectionBulkChange1
            Webdialog set to#<Sketchup;;Group;0x8681b30>
            onSelectionCleared
            Webdialog set to#<Sketchup;;Group;0x86b5238>
            onSelectionBulkChange2
            onSelectionBulkChange0
            onSelectionAdded
            Webdialog set to#<Sketchup;;Group;0x8675518>
            onSelectionCleared
            No version.
            Inspecting model for errors
            onSelectionAdded
            onSelectionCleared
            onSelectionAdded
            Webdialog set to#<Sketchup;;Group;0x86a78a0>
              CPhillips
              That doesnt look like the joint even tries to connect. Are you sure you are holding down the correct key (ctrl on the left side of the keyboard) when you are trying to connect?
                l.frisken
                I did use the left ctrl. It worked with sp2 which is strange, but I'll try right ctrl just in case it is a problem with my keyboard.
                  l.frisken
                  ok thankyou cphillips for solving the prob! I wasn't using the left ctrl like I usually do because I broke my left arm recently, and it is easier to use the right one on my laptop keyboard! but the is still that little glitch with the box in the wrong spot!
                    CPhillips
                    Sorry to hear that. I broke my arm last year and hardly used the computer the whole time it was healing. It was actually kinda nice....
                    I'll make a note to hook up the right ctrl and shift keys.
                      Alpha Wing
                      I had this problem.... Error starting simulation undefined method... nilclass.... etc.......... I need help!
                      • 4 / 4
