    Export > Animation > SWF ?
    5 Posts 3 Posters 1.6k Views 3 Watching
    • JClementsJ
      JClements
      Does anyone know if a plugin has been made (or could be made) to export a model and its scenes as a SWF file?
      Alternatively, is there a SketchUp widget of some sort that allows a model with scenes to be embedded in web page?
      • Chris FullmerC
        Boy, I know someone had a plugin that did something like this. I am remebering these simple little animations that someone was posting, I just don't recall what they were of. Perhaps a search on the old forum would come across the thread.
        Chris
        All my Plugins I've written
        • Chris FullmerC
          Hey, I found what I was thinking of. kkannen had done some animations that were vectorized from SU output. Appears he was using swftools. So check out this thread, then maybe click on his name and check all his threads. I have not re-read them all. Hope that helps for a lead,
          http://betaforum.sketchup.com/showthread.php?t=76851&highlight=flash
          Chris
          • JClementsJ
            JClements
            Thanks, Chris.
            John
            • D
              dtrarch
              Hi All πŸ˜„
              This should work for almost any "movie" format.
              Super translator from and to=====
              http://www.erightsoft.com/SUPER.html
              Such as avi-mov-wmv to swf/flv etc.
              Audio and Video settings.
              I have used this a bunch and no VD.
              It will make you scroll through info before getting to the download and will beg for a small $$$ when you go to settings.
              One will need to know settings for each file formatb but works like sliced bread when you configure correctly.
              β˜€
              Hint: deselect DirectShow Decode [ ]box
              dtr
