    Weld on imported Mesh.obj ?
    5 Posts 3 Posters 635 Views 3 Watching
    • MALAISEM Offline
      MALAISE
      Hi All
      Would it be possible to "close" an imported mesh.obj file ?
      Here is an exemple :
      Weld.rb works for 2 beside edges, but not for a great collection.
      Thanks for any advice...
      MALAISE 😄
      mesh_obj.skp
      • Chris FullmerC Offline
        Are you wanting makefaces.rb? All your edges seem nicely joined, but there are many missing faces. Make faces will take care of that. Its here:
        File Not Found
        (www.smustard.com)
        Chris
        All my Plugins I've written
        • ely862meE Offline
          ely862me
          I think this can be usefull...thx!
          Elisei (sketchupper)
          Come and See EliseiDesign
          • MALAISEM Offline
            MALAISE
            Thanks Chris for the help !
            I made a try on an heavy model, 92% of the missing faces have been closed.
            MALAISE 😄
              Another of my favorite tools for this stuff is Stray Lines. Often when a face does not close it is because the lines don't actually meet up correctly. So label stray lines goes through and puts a little text tag at each line end that does not meet another end. So you can see VERY easily all lines that don't actually touch. Sometimes theya re obvious, but often they are virtually impossible to find w/o this tool.
              Chris
              EDIT: To make it more clear, once the lines are labeled, it then makes it clear where to go to start filling in the missing segments, deleteing, extending lines, etc.
