    Ruby Importer API Crash
    3 Posts 2 Posters 448 Views 2 Watching
      Jim
      Sang Ahn has posted an introduction to the SketchUp Ruby Importer API on the SketchUp API Blog. The API allows you to put your import in the File > Importers menu, for one.
      However, my simple test of the API crashes SU repeatably. Can anyone confirm the following code crashes SketchUp? If so, I'll file a bug report.
      You can see the importer does appear in the correct menu:
      But here is the result just before BugSplat:
      Here's the code. You can see all it does is print the file:
      class JfObjImporter
        def description
          # Returns a brief description of your importer plugin.
          "JF OBJ Importer (*.obj)"
        def file_extension
          # Returns the file extension of the file format your
          # importer can read (e.g. fbx, dae, etc.)
          "obj"
        def supports_options?
          # Returns true if your plugin supports import options.
          false
        def do_options
          # Presents the import options dialog panel to the user.
        def id
          # Returns the id string of your importer.
          "JFimporterID"
        def load_file(file_name, show_summary)
          # Reads the contents of location on disk specified by file_name.
          # Shows the summary dialog panel if show_summary is true.
          p file_name
          IO.readlines(file_name).each do |line|
            puts line
      Sketchup.register_importer JfObjImporter.new
      Here's the file:
      ExampleImporter.rb
        sangahn
        I left out an importer detail in the blog post.
        load_file
        needs a return code. Returns 0 on success, 1 on error. D'oh!
          Jim
          That fixed it! Thank you, Sang. πŸ‘
