    This is cool! SU render - yep SU!
    37 Posts 17 Posters 9.7k Views 17 Watching
    • RichardR Offline
      Richard
      Thanks Majid
      I hope now I get to see some people trying it out for great results (hint, hint)!
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
      • RichardR Offline
        Richard
        Just wondering if anyone has had a go at this yet with any results?
        • K Offline
          kwistenbiebel
          Yes, I am starting to use the method at work. Not quite at the same level as you yet, but it is refreshing to use the D method.
          Can't put the office images here though.
          • RichardR Offline
            Richard
            Darn! Would love to see someones attempts! 😄
            • RichardR Offline
              Richard
              Just testing again with the same model to work out a defined workflow - this time using a depth image (black fog, front/back faces white) to mask the lens blur.
              This seems to give better and more predictable results.
              I followed a slightly different work flow with this one;
              SU export: monotone mode light faces are reversed normals (could be done with just face colours though)
              1. Fog, shadows left, line on (light front face, dark back face)
              2. Fog, shadows left, line off (light front face, dark back face)
              3. Fog, shadows right, line on (light front face, dark back face)
              4. Fog, shadows right, line off (light front face, dark back face)
              5. Fog, shadows off, line off (white front face, white back face) depth map
              PS edit:
              A. Normal blend 1 and 2 to get preferred line weight, merge layers
              B. Normal blend 3 and 4 to get preferred line weight, merge layers
              C. Black fill background layer
              D. Apply layer mask to A / B layers using depth map
              E. Apply lens blur (with noise) to A / B using mask as source
              F. Apply filter > Artistic > film grain to A / B layers
              G. Normal blend Layer A / B to get preferred shadow cast
              H. Copy merged > paste new layer
              I. Apply Filter > render > lighting effects, create lights from direction of light sources and adjust to suit
              J. Apply Filter > distort > lens correction - use negative correction to add distortion, lighten vignetting to light extremes from light source,
              K. Use shadows and highlights edit to fix shadow depth etc.
              L. Adjust levels.
              This image uses three lights in PhotoShop all added in same action
              1. Bottom left toward center
              2. Bottom right toward center
              3. Top left toward back center
              Still amazed this can be done with SU.
              http://img13.imageshack.us/img13/623/40025454.jpg
              Close Up
              http://img13.imageshack.us/img13/6322/71322752.jpg
                Dennis_n
                for some reason the image does not show up here in China.
                could you repost it?
                • RichardR Offline
                  Richard
                  I've attached it Dennis (just the close up anyway)!
                  I think you'll find this pretty cool when you consider it is pretty much just two SU images with little bit of PS.
                    Dennis_n
                    lens blur is particularly effective.
                    I felt like I'm back to school and staring at a photo of a card board model.
                    • soloS Offline
                      solo
                      Richard, maybe add some 'BLOOM' 🤣
                      Sorry, could not resist.
                      http://www.solos-art.com
                      • E Offline
                        Ecuadorian
                        And here comes the bloom...
                        Same photo, but with the wrong flash setting:
                        -Miguel Lescano
                        • RichardR Offline
                          Richard
                          That's cheeky Pete!
                          • StinkieS Offline
                            Stinkie
                            Just revisited this thread. I still feel these look great. Come on, Richard, do some more! Chop-chop!
                            By the way ... Ecuadorian, how did you create the below image? Looks just like a Tuymans painting.
                            http://forums.sketchucation.com/download/file.php?id=33420&mode=view
                            • RichardR Offline
                              Richard
                              Yeah bit surprised Stinkie that we haven't seen a few more attempts at this style seeing it is so easy, even from myself!
                              • StinkieS Offline
                                Stinkie
                                Dunno about the 'easy' part, Richard. I've not been able to match your images so far. 😄
                                • RichardR Offline
                                  Richard
                                  Oh! Wasn't sure anyone had given it a go! Maybe it is simply in part the context of the shots lending themselves very well to this type of render!
                                  • StinkieS Offline
                                    Stinkie
                                    Possibly. Going to keep at it, though. Interesting process.
                                    • RichardR Offline
                                      Richard
                                      Mate I think the two most important processes are to get two differing sun shadows - you can test this in SU by bringing your first image in as a watermark! Then the other is ensuring your light effects added in PS post pro match closely the sun directions from SU!
                                      Also obviously the choice of line type and density on at least one of the SU exports!
                                      • 2 / 2
