    This is cool! SU render - yep SU!
    37 Posts 17 Posters 10.5k Views 17 Watching
    • RichardR Offline
      Richard
      Three exported images, now just a few min post work in PS and presto about as close as I reckon I've seen to a render from SU!!!
      This is cool!
      http://img243.imageshack.us/img243/638/niceir8.jpg
      BUILTBRAND.COM.AU
      • K Offline
        kwistenbiebel
        Is this default SU output and Photoshop?
        In that case. Wow!
        • broomstickB Offline
          broomstick
          I am not understanding this. But if I am... just wow, post a tutorial man!
            Sir
            heh looks like a cardboard model 👍
            • RichardR Offline
              Richard
              In that case. Wow!
              Yes mate just SU image export! Then little bit of PS! Got it bit close third time! Still the next one!!!! Not tonight though! Excuse the model this is still being designed now! Lots of ground remodelling to go! And about the large images though they lose the effect quickly when too small!
              This is seriously simple and fast! and Controllable!
              I'd be happy to get that from maxwell!
              http://img12.imageshack.us/img12/4390/28827895gd3.jpg
              BUILTBRAND.COM.AU
                Teezer
                Very nice model, Richard. It must be someplace where it never snows... 😄
                Real life is just another website, albeit a rather boring one.
                • RichardR Offline
                  Richard
                  You're right mate! 7m height limits roofing too! Dam!
                  BUILTBRAND.COM.AU
                    thoscon
                    Very Nice!
                    I second the request for a tutorial!
                    • EarthMoverE Offline
                      EarthMover
                      Very cool Richard! What's the secret, lens correction, slight blur, noise layer?
                      Content Creator at Skapeup
                      • Chris FullmerC Offline
                        Its great Richard. I have one complaint though, its too noisy for me. In my mind the noise from maxwell and others has always driven me away from them. So purposely duplicating it seems silly. now I reckon a little bit of noise helps make it appear more photo like and less CG, but that second one for sure feels more noisy than not. But thats just my opinion of course. I'm sure its something that could be controled to the users likings in the process. All in all though, very nice!
                        Chris
                        All my Plugins I've written
                        • P Offline
                          putnik
                          I actually like the noise Chris. For a massing study it's very appropriate. Gives the drawing a bit of graphic depth. And the black sky here is good too. 👍
                          http://keshas.info
                          • K Offline
                            kwistenbiebel
                            Yes, What are your tricks there Richard? 😉
                            This is a good study on why things look photoreal.
                            Is it the noise introducing a bit of randomness?
                            Makes you wonder what all the hype about Maxwell was about.
                            I sometimes have the feeling it is exactly that noise of an unfinished render that makes it look real.
                            If you let it render until it is really really clean, is the quality that much better than a Vray render?
                            • RichardR Offline
                              Richard
                              Thanks guys!
                              I possibly do agree with Chris F. that the noise is a little over done (film filter) though I went that way though as the model has no textures!
                              At the moment the process is still a bit hit and miss, though I hope to get that worked out and will post a workflow!
                              It is interesting as to what makes an image look convincing! Here for starters (particularly the second) is a quick and dirty trick it get fairly close to rendered output with less mucking around then any render app just a few image exports! I do't think this will work as well, well it wont, for fully textured works as there are no reflections or spec and the lighing really only suits these type of massing studies. Though using lower res textures on the model could certainly give a better idea of the finishes as if the surfaces where printed on paper and stuck to board prior to model construction.
                              At the moment I'm finding it a case of getting the shadows fog and line style right then the rest is a bit of trial and error (at this stage) in PS with layer weights, blending and filter application.
                              BUILTBRAND.COM.AU
                                matteo
                                great images! they look to be the ideal solution for those dirty quick works where you don't have enough time to cook a render 👍
                                hire me: http://www.nonsolo3d.it/ !
                                • E Offline
                                  Ecuadorian
                                  My best guess now that he has given us some clues:
                                  Perhaps he generated a depth map from SU using black fog with almost white edges in hidden line mode, then loaded that depth map in Photoshop, and used it as a mask for a couple of adjustment layers and for lens blur, and added a little grain texture to finish it.
                                  Check the last tut in this page:
                                  http://sketchup.google.com/training/videos/expert_to_gsu.html
                                  In the video the narrator uses the trick to achieve lens blur, but you can use that same mask for other effects. If you apply it as a "Multiply" layer and modulate it a bit, you can give the impression of using a headlight.
                                  Another related trick: Place two cameras really close, export a JPG animation from them, average the result in VideoMach and voilá! Motion blur from SketchUp.
                                  -Miguel Lescano
                                    linea
                                    However you did it Richard, I look forward to your tutorial.
                                    • K Offline
                                      kwistenbiebel
                                      Hi Richard,
                                      Thanks for that little tut.
                                      Together with the Dennis technique and Worncall (or is it Cornwall?) this produces nice images.
                                      I am going to do more NPR images again as I find that photoreal rendering in pre-design gives you nothing but trouble towards clients.
                                      • RichardR Offline
                                        Richard
                                        Hi Richard,
                                        And like you said on the PPB mate they are MUCH more fun!!!
                                        BUILTBRAND.COM.AU
                                        • RichardR Offline
                                          Richard
                                          Still trying to get back to playing with this!
                                          Richard's Render Technique:
                                          These images where taken with fog on monotone SU (road normals flipped), default colours changed to suit. The Fog needs to be onto the subject to get good depth.
                                          The ground model was unsoftened edges and some small random pushpull to subtly disjoint the surface.
                                          Images where exported for two sun angles, both lines (sketchy edges) on and off.
                                          Images layered in PS:
                                          Play with layer blending (no set blend, sun angles make a difference) - when correct the effect will jump out.
                                          lense distortion (CS3 - lens blur older not as good) to some.
                                          film grain filter to some.
                                          AND the big one - Render lighting!!! Render two or more? spotlights (best to separate layers) from the directions of your sun! Remember also lights in PS can be used as light suckers which are useful!
                                          A bit of shadows and highlights filter on some of the layers will if the radius is tuned will provide an almost added render effect of sticking shadow to edges.
                                          The blurr tool can help to blurr the outer for DOF effect. And sharpen edges filter on the top layer as final.
                                          As suggested earlier yeah the film grain what you want but I upped it a bit to give texture to the board!
                                          I said "to some" a bit as the weight of your layers will bear on the effect apllied, layer weight will be effected by your sun angles. I find you want two differing intensity shadows with the PS lights adding to the sources and dominance of the lighting direction.
                                          And its all just light bits most effect you may want to Edit > fade: "last effect".
                                          Cheers, Richard
                                          BUILTBRAND.COM.AU
                                          • majidM Offline
                                            majid
                                            dear Richard you r so creative person . Isaw your work whit layout too. interestiny . and also your new trik is fantastic. keep growing.
                                            • 1 / 2
