    Lights Please
    9 Posts 5 Posters 855 Views 5 Watching
      tesmeko
      I know it lack lights from the inside,
      but how can you make it not look like a disco or batman's light signal that all of a sudden turned on?
      thanks.
      Tesmeko
      keep sketching
      • soloS Offline
        solo
        Thats one heck of a curb you have there, how do the cars get onto the road?
        As for the light thing, what render app are you using?
        http://www.solos-art.com
          tesmeko
          Its actually a 6meter driveway but id rather show the car parking it rear first as it would actually be easier to drive around.
          its vray. but i only loaded one of its files an here it is.
          but hold on solo,
          hows the new SU Podium, I was waiting for it to come out and hear some more feedbacks and reviews, but I guess you're the most qualified to speak about it..... well comparing ofcourse to the previous SU podium.
          Ive tried the previous demo but i couldnt make things softer as it turns out to be very squarish....
          Thanks in advance for the suggestions and comments.
          Tesmeko
          keep sketching
          • honoluludesktopH Offline
            honoluludesktop
            Not an expert in this, but if you are thinking of light coming out of the window, I would place a wall behind the window (on the inside), and use a non-directional light on the wall.
            The curb that Solo is referring to is the vertical yellow object between the road and the sidewalk. The perspective gives the impression that it is almost as tall as the children.
            • DanielD Offline
              Daniel
              Tesmeko, even with lights on inside, you wouldn't see them from outside during daytime. At best, they'd look like small point lights. You should add either a blue sky or background to your model, as the great white space beyond makes it appear incomplete. Also, adjust the sun angle some, so the hip ridge on the roof is more pronounced.
              My avatar is an anachronism.
                sepo
                ...and much better texturing....Must admitt I did not understand the comment on "squarish". Care to elaborate?
                  tesmeko
                  Sorry for the mix up guys.
                  The crub right there in the front is actually a fence. Fences right here in the Philippines tend to be really high, but Im not in the position to really negotiate to put it down like picket fences. Almost all of my clients would like to have privacy from the outside, cant disagree.
                  To Daniel:
                  Thanks for the suggestion, im not really good at this but id try to make things one at a time if i have time to spare like weekends, but its so hard nowadays since i have my hands full covering several projects on my own and going to the construction site to see how things are going. Plus I have a pregnant wife due on march......
                  To Sepo:
                  Im not really sure if its squarish or is it just the demo that only brings a small images. But looking closer I feel that Im just started using 3d in autocad and rendering it without shadows or anything. Im not good at 3d rendering I must admit, but Im working things out because I can make architectural models and I feel that its inefficient for me to present it if I cant make this realistic or near realistic.
                  keep sketching
                    tesmeko
                    I made the fence smaller so i can get a better view....
                    I just pushed the fence down so it looked the way it is right now. I wouldnt see anything if the fence was high....
                    Tesmeko
                    keep sketching
                      sepo
                      I see, you were reffering to demo restriction. Yes, demo is limited to 500x500 output.
