    Nested operations
    3 Posts 2 Posters 422 Views 2 Watching
    • A
      avariant
      I think I know the answer, and the answer is no, but I figured I'd check.
      Can you nest start_operation, commit_operation calls? For example:
      model.start_operation "Operation A"
      #do something
      model.start_operation "Operation B"
      #do some more stuff
      model.commit_operation  #ending operation B
      #do some final stuff
      model.commit_operation  #ending operation A
      I figure the answer is that it at least won't work the way I want. What I would expect is that the outermost start / commit (Operation A), would be the only one exposed in the Undo / Redo because it contains Operation B within it. But what I think I see is that both A and B show up in the menu. This seems bad, because it implies that some operations from A are either being attributed to B, or being handled outside all the operations entirely. Anyway, does anyone know a more official explanation? The API, as usual, says very little on the subject. πŸ˜‰
      • T
        todd burch
        No, you cannot do nest commits. Assume the behavior is undefined.
        • A
          avariant
          Ok. thanks!
