    [HowTo] update view to make animation
    6 Posts 3 Posters 616 Views 3 Watching
      MarcioAB
      Hello - Happy 2009 for all of us.
      I'm just finishing a new version of a script (JointSU) but I can not show the "animation" of an instance in SU. I need help to find how to update the View for each step in a loop. For example, consider the code below:
      transf=Geom;;Transformation.rotation(pt,vector,angle)
      for i in 1..10
       instance.transform!(transf)
       sleep(1)
      When I run this code, I just see the instance in the initial position, 10 seconds of nothing and the instance in the final position and not each intermediary steps.
      In a trial and error basis, I tried Sketchup.active_model.active_view.invalidate, Sketchup.active_model.active_view.show_frame, Sketchup.active_model.active_view.draw but no luck.
      Any help is much welcome.
      Regards
      Marcio
        todd burch
        All you need should be to invalidate the view inside your loop, as long as you have a Tool class. Post a small, complete, failing example.
        Todd
        • MALAISEM Offline
          MALAISE
          Hello MarcioAB
          Best wishes for 2009
          Your script sounds promiser, let's know us your improvements 😄.
          MALAISE
            MarcioAB
            Todd
            This is the code I was expecting to work:
            def callA
              joint=JointSU.new # see explanation below
              Sketchup.active_model.select_tool(ViewSpinner2.new(joint))
            class ViewSpinner2
            def initialize(j)
              @jointSU=j
              r=@jointSU.getParentComponents
              @c=r[2]
              t2=r[0].transformation
              @t=Geom;;Transformation.rotation(t2.origin,t2.xaxis,-PI/45.0)
              for i in 1..10
               @c.transform!(@t)
               sleep(0.1)
            end # Class
            No error message. I see the @c instance in the first position and than in the last position. I do not see the intermediary positions.
            Obs: JointSU is now a (long) class (I will post it later today), but for this discussion, the method "getParentComponents" provide data to allow establish a point and an axis for the @t rotation transformation.
            On the meantime I just found this code in the examples and it works:
            def callB
              joint=JointSU.new
              Sketchup.active_model.active_view.animation = ViewSpinner.new(joint)
            class ViewSpinner
            def initialize(j)
              @jointSU=j
              @c=r[2]
            def nextFrame(view)
              @c.transform!(@t)
              view.show_frame
              true
            end # Class
            But I still prefer the first one - if it worked (must be missing something I can not see ...)
            Marcio
              MarcioAB
              @malaise said:
              Hello MarcioAB
              MALAISE
              Welcome. I'm having fun with this. I will post it later today.
              I need to include some animation of the bike based on it's joint-enabled-components.
              ... and some documentation.
                todd burch
                Sorry, if I'm going to debug this, I require a complete, small, failing example. I'm not going to try to reverse engineer your snippets.
