    Aliasing UI::messagebox ?
    4 Posts 3 Posters 622 Views 3 Watching
    • scottliningerS Offline
      scottlininger
      Hey guys,
      So I'm trying to override the UI::messagebox method so it doesn't bark at me while I'm running a bunch of unit tests. That bit was easy...
      def UI;;messagebox(params)
        puts 'TEMPORARY OVERRIDE; UI;;messagebox > ' + params.to_s
      So far so good. But once I'm done with my tests, I'd like to return control back to the default UI.messagebox. I tried various flavors of the alias and alias_method keywords, but those don't seem to work with modules. I'm certain there's a way to do it, but I thought I'd ask here before diving into my Ruby books. Hopefully it's a simple syntax hiccup.
      Thanks in advance, oh Ruby masters,
      • Scott Lininger
        SketchUp Software Engineer
        Have you visited the Ruby API Docs?
        todd burch
        This will do it. I wish there was an unalias_method. I got around it with a global.
        # ruby example to temporarily override a method
        require 'sketchup.rb'
        $no_msgbox = true ;
        module UI
        	alias_method ;messagebox_real, ;messagebox
        	def UI.messagebox(string)
        		if $no_msgbox then puts "UI;;messagebox -> #{string}"
        		else messagebox_real(string)
        	end # def
        end # module
        include UI
        UI.messagebox "see me print in the console..." ;
        $no_msgbox = false ;
        UI.messagebox("Back to the real messagebox")
          scottlininger
          Thanks, Todd! That'll do nicely.
          • Scott Lininger
          • Dan RathbunD Offline
            Dan Rathbun
            ... I tried various flavors of the alias and alias_method keywords, but those don't seem to work with modules. I'm certain there's a way to do it, but I thought I'd ask here before diving into my Ruby books.
            Yes.. it's weird that alias doesn't work with modules.
            But this is even weirder. To alias modules, you instead use the object= method.
            Example aliasing of Sketchup module: (At Ruby Console type the following, where ">>" is resulting output.)
            Sketchup.class
            >> Module
            Sketchup.object_id
            >> 43353420
            # remember this id...
            # now alias the module
            SU = Sketchup
            >> Sketchup
            SU.class
            >> Module
            SU.object_id
            >> 43353420
            # it's the SAME exact id
            # test it...
            SU.version
            >> 7.1.6087
            I would think that we must be careful what namespace the alias constant is declared within. If the above statement "SU = Skecthup" was declared inside a module, or a class, it would only be accessible within that namespace, or must be qualified to be accessed.
            For example, say you used that alias assignment within a module named "Configurator", in order to access the alias from outside, you'd need to qualify it with:
            Configurator::SU.methodcall
            However.. if you wished the alias to have global public access, you'd need to declare it outside ALL modules, in the objectspace. (Similar to typing it at the console.)
            BUT... what if for control purposes (ie, conditional loading,) you needed to have the statement inside a class or module?
            I think in this case, remember the Kernel.eval() method, and the fact that module Kernel is included in every object. That means that the containing module has it's own copy of eval. So you cannot call just eval (unqualified,) because you'd be calling the local module's copy of eval.
            To do it from within a module (or class,) you must qualify the call:
            if situation then Kernel.eval("SU = Sketchup");
            Then the alias constant is global.
            I'm not here much anymore.
