    Suggestion for code - Minimize (rollup) Outliner
    11 Posts 7 Posters 2.6k Views 7 Watching
    • JClementsJ Offline
      JClements
      If you run an intensive script in a model with lots of groups and components and have the Outliner open and maximized (rolled down), then things can come to grinding halt (or nearly a grinding halt).
      Could a block of code developed which could be used in new or existing scripts or called from within a script which would do the following????:
      1- Check to see if the Outliner is open and maximized (rolled down). If so, Roll it up or close it.
      2- Then execute the intended script.
      3- When the intended script is finished, the Outliner is Rolled down or re-opened ... to whatever state it was prior to running the intended script.
      John
        Jim
        That's a good suggestion, John.
        I tried a quick experiment. It is possible to shade the Outliner from Ruby, but I don't see a way to tell if it is currently open. Anyone have an idea about that?
        Note that the Ruby API in SketchUp 7 has changed to address this issue. The change is in the start_operation method:
        SU 6:
        Sketchup.active_model.start_operation("Create a zillion faces")
        versus SU 7:
        Sketchup.active_model.start_operation("Create a zillion faces", true)
          CPhillips
          I wrote this up a while ago. I am pretty sure I sent it to you Jim...
          def toggleRollUp(name)
              findWindow = Win32API.new("user32.dll", "FindWindow", ['P','P'], 'N')
              pw=findWindow.call(0,name)
              sendMessage = Win32API.new("user32.dll", "SendMessage", ['N','N','N','P'], 'N')
              sendMessage.call (pw,0x00a1,2,"")#WM_NCLBUTTONDOWN
              sendMessage.call(pw,0x0202,0,"")#WM_LBUTTONUP
          def isRolledUp(name)
              getWindowRect= Win32API.new("user32.dll", "GetWindowRect",['P','PP'], 'N')
              data=Array.new.fill(0.chr,0..4*4).join
              getWindowRect.call (pw,data);
              rect=data.unpack("i*")
                  #if window height is less than 90 then the window is rolledup
              return (rect[3]-rect[1])<90
          • K Offline
            kwistenbiebel
            Wow, this is an excellent idea.
            The outliner is a fantastic tool when editing.
            But it is indeed a pain in the ass when you got it open while using heavy scripts.
            This (future) script might save me a headache 😄
              Jim
              You would still need to add it every existing script you want to use it in.
                JClements
                Jim F:
                So if CPhillips' code can be stored as a .rb and is given a name like "Outliner_Rollup.rb" and it is located in the SU/Plugins directory, what code would need to be inserted into a script to call Outliner_Rollup.rb and where should it be placed relative to the existing code?
                John
                  CPhillips
                  @jclements said:
                  Jim F:
                  John
                  I added hideOutliner() and restoreOutliner(). Just call before and after your script respectively.
                  require "win32api.so"
                  #these 2 functions are untested but should work.
                  def hideOutliner()
                     $bOutlinerWasOpen=!isRolledUp("Outliner")
                     toggleRollUp("Outliner") if $bOutlinerWasOpen
                  def restoreOutliner()
                    avariant
                    While you'll still need a method to determine if the Outliner is visible or not... you can just call this:
                    UI.show_inspector "Outliner"
                    to toggle between rolled up and rolled down. (At least in SU 7, didn't try 6)
                      alz
                      Had a similar problem awhile back and just hacked it by adding "Sketchup.send_action 21926" before/after the function to temporarily hide all the dialog windows.
                      The above ideas are more elegant and official, however
                      --alz
                        Jim
                        Is this still valid for Ruby 2, or is there now a better way using the Ruby StdLib?
                          johnzdennis
                          I see this thread is almost ten years old, but has this issue ever actually gotten fixed?
