    Question - A way to allow user to change ruby menu location?
    2 Posts 2 Posters 386 Views 2 Watching
    • JClementsJ
      JClements
      I was wondering if the is a way for a script (particulary those that are protected in .rbs format) to change which SU menu the script appears in?
      I understand how to manually manipulate most .rb's, but it would be very convenient if a standard block of code be developed which would allow the user, on the fly, to change the Menu they'd like the script to appear in. Perhaps be a standalone file in the plugin directory which a script could make a call to?
      Regards, John
      P.S. I realize there ways to reorganize the scripts into a custom UI, but I thought there might be a simpler way of organizing scripts utilizing the existing/out-of-the-box SU Menus.
      • A
        azuby
        Difficult. You can't change it while Sketchup is running -> restart. But you can try to override the Sketchup methods for adding (sub) menus and menu items keeping the old methods with alias names. Your methods "hook" into the old methods, before they perform their action - short IRB session explaining what I'm talking about:
        irb(main);001;0> class A
        irb(main);002;1>   def a
        irb(main);003;2>     puts "a"
        irb(main);004;2>   end
        irb(main);005;1> end
        => nil
        irb(main);006;0> class A
        irb(main);007;1>   alias ;old_a ;a
        irb(main);008;1>   def a
        irb(main);009;2>     puts "b"
        irb(main);010;2>     old_a
        irb(main);011;2>   end
        irb(main);012;1> end
        => nil
        irb(main);013;0> A.new.a
        b
        a
        => nil
        Your method could read the correct menu structure i.e. from a text file. But you have to make sure, that your script is eval'ed by Sketchup before another script adds menus or menu items.
        azuby
