    [HowTo] Make SendKeys (WIN32OLE) works "immediately" ?
    3 Posts 2 Posters 1.0k Views 2 Watching
    • M
      MarcioAB
      I'm trying to follow this topic from TIG to be able to Open/Close Components but it is not working as I was expecting. SendKeys only sends the key after all code finish and not immediately, example:
      Assume I have "x" as a shortcut to "Edit/Close Component", a child component Opened (Edit) and want to Close it. This is the code:
      def test
      p Sketchup.active_model.active_path
      WIN32OLE.new("WScript.Shell").SendKeys("x")
      The first Active_path show
      [#Sketchup::ComponentInstance:0x4a79290, #Sketchup::ComponentInstance:0x4a79278]
      but the 2nd Active_path (still) show
      Because ComponentInstance:0x4a79278 was Closed, it should show
      [#Sketchup::ComponentInstance:0x4a79290]
      When the above code finish in fact the Active_path is on [#Sketchup::ComponentInstance:0x4a79290], but not ("immediately") during the code execution. It's like SendKeys kept "x" buffered and just release it when SketchUp assume control.
      Am I missing something, Can SendKeys works immediately, or Is there a workaround ?
      Thank you
      Marcio
      • W
        wikii
        Pause the script a little moment to allow SU responds to the command of "close components".
        • M
          MarcioAB
          😳 Just discovered I can Close components with "Sketchup.active_model.close_active"
          Thank you, but even with sleep(5) and bring the window to focus ... no success to trigger "Edit Component" shortcut ("Y").
          s=WIN32OLE.new("WScript.Shell")
          p s.AppActivate("SketchUp")
          sleep(5)
          p s.SendKeys("y")
          sleep(5)
