    Some rendered models
    6 Posts 2 Posters 892 Views 2 Watching
      Jeri
      Hi everybody,
      Here is a some models I made in SU 6 and rendered with IDX Renditioner. The vegetation is added in PhotoShop.
        bahjon12
        hi jeri..
        great render .......
        may i ask ....how did you get the effect of the water falling over the infinity edge?
          Jeri
          The water effect is a picture imported as texture in SketchUp. Scaled to match the height and repeated horizontally to fill out.
            bahjon12
            thanks jeri...
            i've tried it some of my renders...(i use vray for SU)...
            but i never seem to get the effect in the rendering....it seems to work fine when i import and apply it as a texture in the model..but the effect just fizzles out in the rendering...
            any suggestions??...
              Jeri
              This is the texture I used:
              http://www.cgtextures.com/texview2.php?id=26706&PHPSESSID=faa8f9458e1c0819dc18cb22edb5706b&time=1230018700
              Check it out, download it and give it one more try.
                bahjon12
                thanks jeri.....
                will definitely give it a try....
                i'm working on a residential project right now that has an infinity edge pool...still in the conceptual design stage...but will definitely post images when i do the 3d model...
