    Cottage (WIP)
    12 Posts 7 Posters 1.2k Views 7 Watching
      Crazy Eyes
      Hi all
      I'm making a model of the first cottage in my town, some 100 years young. I'm trying to render it in V-Ray, but are having issues with some of the groups/components not showing up on the render. If I explode the group/component then it render fine. The example here is the skirting in the lounge. It shows in the SU 2D export, but not in the V-Ray render.
      Can anyone help me with this? I don't want to ungroup everything that doesn't show.. it will make alterations a headache.
      Pre-Ta
      Crazy Eyes
      Ps. I thought that I'd include an external render too.
      Some people are lovers, some are fighters, if you love to fight, fight for love!
      • X Offline
        XamalA
        I can help you!
        Maybe...
        but, I had the same problem to. The one I know, you cn't group something, and group it again(double group).
        If I fac the same problem, i explode it, and regroup it.
        If it won't work, try if you double group something, ex: you group a car rim, and group the rim with the tyre, the rim will be invisible. Solution : open the group, and explode rim group. or explode the group, unselect(CTRL+SHIFT+click) rim group, and group the tyre.
        • dcauldwellD Offline
          dcauldwell
          This 'component not rendering' thing was a known problem in earlier releases.
          The latest release (01.05.03) has fixed this.
          It is important to apply textures within a component, not to the component as a whole.
          Good Luck
          David
          Sketchup 2017
          (vray 2.00)
            Crazy Eyes
            Ok, thanks... that seems to have worked, the groupings are showing up now.
            I'm am still making a little more every day.
            I've done a couple more renders. Any c&c's are more than welcome.
            • pbacotP Offline
              Your cottage detail is impressive, one really see how it's put together. I love the roof eave picture. The rendering really shows off the excellent modeling. Is this cottage down under, by chance?
                Crazy Eyes
                Thanks for the nice comment and yes, the cottage is from New Zealand. How did you guess?
                • MarianM Offline
                  Marian
                  Congrats, Lyall, nice cottage you have there πŸ˜›, love those details too, you should put a christmas tree near the fire place and a sock on it πŸ˜›
                  • pbacotP Offline
                    @crazy eyes said:
                    @pbacot said:
                    Your cottage detail is impressive, one really sees how it's put together. I love the roof eave picture. The rendering really shows off the excellent modeling. Is this cottage down under, by chance?
                    I was in New Zealand once ('85) and I noticed the Victorian style with the metal roofs--especially the curved eaves, which is not as common in the U.S.
                      Crazy Eyes
                      I trying to make the weatherboards look more realistic. I would imagine doing this with a bump map. Does anyone have a suitable bump map with the appropriate settings for vray that I could try?
                      • StinkieS Offline
                        Stinkie
                        Did you take a peek at the material repository over at asgvis.com? This is a good source, too: http://www.3dtraining.ch/index.php?option=com_content&task=view&id=61&Itemid=145
                        As for the dissapearing components, in my experience this happens with the latest build of VfSU too. However, you needn't explode them. Closing your file and opening it again helps too.
                          Crazy Eyes
                          Thanks guys for your support here. I've had a look at the sites you suggest and that gave me inspiration to generate my own bump map. I've done a cursory render just to see how it will look with the wood texture. I think that I will have to tone down the bump map so the lines don't look as deep, but I'll let your comments decide for me. Also, is there an easy way of altering the positioning of the bump map so that the weatherboards don't have the same lines in the same places?
                          • DanielD Offline
                            Daniel
                            Nice modeling and detailing. Two minor issues: in the first image, the wood grain on the jamb should be running vertical, not horizontal; and in the last image, the bump texture on the rake should be running parallel to it's slope, not horizontal.
                            My avatar is an anachronism.
