    Brand spankin new project...
    5 Posts 3 Posters 638 Views 3 Watching
      bubbalove
      Here are 3 renderings of a commerical project we are doing here in NC. Rendered in Kerky with preset no. 17... each one took about 3 hours to render so I could get rid of most of the noise. Everything was modeled in Sketchup of course and the cars are from FF. The grass could've been better! I tried to do use the clip map method about a 1 or 2 above the ground plane but it didn't really turn out as I expected... should've used the grass models with the instancing brush! In image 1, the car mats are too shiny so I fixed them in the rest... not really noticeable unless I tell you or you have a keen eye... enough talkin... what'cha think?
      http://img509.imageshack.us/img509/516/final1ox2.jpg
      By bubbalove at 2008-12-17
      http://img401.imageshack.us/img401/2179/final2li8.jpg
      http://img140.imageshack.us/img140/3402/final3be4.jpg
      "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
      • DanielD Offline
        Daniel
        Wow, David, I'd say those were really great looking, but I know for a fact that the NC Handicap Code requires pole-mounted or building-mounted signs at the accessible parking spaces, and your careless disregard for such details ruins the experience for me.
        My avatar is an anachronism.
          bubbalove
          Ouch! πŸ‘Š All right Daniel... I didn't wanna piss you off or anything cause I forgot to put in the HC signs... so I put some in just for you in PS...
          • boofredlayB Offline
            boofredlay
            πŸ˜† Daniel you crack me up.
            David, these are great. The one thing that sticks out to me however is how even your pavement texture is. It just does not seem real enough. If it helps, I have had great results with this texture: http://www.sketchucation.com/forums/scf/viewtopic.php?p=111655#p111655
              bubbalove
              Thanks Boo, I'm sure there will be some changes so if I do get to render these again I will try to use the texture you provided!
