    [Wishlist] Edit Component
    1 Posts 1 Posters 575 Views 1 Watching
      MarcioAB
      There is a close_active method in Model class to close an opened instance of a component.
      An active_path method in Model class to show the parents of an instance of a component.
      A trick to open (edit) a component in this topic
      A private open method in Model class probably to open (edit) an instance of a component ...
      Why this private open method is not made public ? (or why not a method to open (edit) an instance of a component?).
      Obs: must be the instance, because the open (Edit Component) allows access to the positioning of that particular instance.
      Thank you
      Marcio
