    Graphics card problem ??
    15 Posts 3 Posters 2.0k Views 3 Watching
    • G
      guzman tierno
      I'm installing sketchup in the computers of the school where I work now,
      but I'm having problems with some of them.
      Skethup installs but freezes at startup.
      The computers with problems have the following
      graphics card: via s3g unichrome igp.
      I think that this is problem.
      I updated the drivers but the problem remains.
      Any ideas, suggestions, ... ?
      Thank you.
      • soloS
        solo
        I suspect that may indeed be the issue, what operating system are you using?
        I believe your systems run on a North bridge Via mobo, with integrated graphics right?
        http://www.solos-art.com
        • G
          guzman tierno
          XP, sp 2
          AMD sempron
          I dont know, how can I check that ?
          [igp actually stands for integrated graphics processor]
          thanks
          • soloS
            solo
            No need to open up to find out, as you said it's an AMD sempron, so it's single core with integrated graphics presumably 3d now technology (2004/5 build)
            It should work, you may need to turn off 'accelerated graphics' to 'software' in preferences.... if you can get SU to actually start.
            • G
              guzman tierno
              Thanks Solo,
              the problem is I cant get su to start, it freezes at startup without showing the menu bar.
              Is there any way to set preferences from a command line ?
              thanks.
              • sketch3d.deS
                sketch3d.de
                run XP in safe mode (= standard, lame, low-res Windows drvier), press F8 several times during boot for getting the menu concerned.
                hth,
                Norbert
                • G
                  guzman tierno
                  @sketch3d.de said:
                  run XP in safe mode
                  Thanks Norbert,
                  I'll try that.
                  • G
                    guzman tierno
                    I hope to find a solution 'cause otherwise I wont be able to make my (middle school) students use Sketchup
                    and that would be very sad,
                    • sketch3d.deS
                      sketch3d.de
                      I hope to find a solution ...
                      you may alse evaluate replacing your shared low-end graphics sub system by something capable, i.e. a dedicated video card which will surely show a big boost on display output speed during screen transformations.. as well as running more stable w/ SU.
                      on older system with an AGP port only a nVidia GeForce 7900/7950 GS/GT is the fastest you can get.
                      hth,
                      Norbert
                      • G
                        guzman tierno
                        That could be a good solution,
                        is it difficult to mount the graphic cards ?
                        are they expensive ?
                        Thank's a lot,
                        I didnt know how to face this problem,
                        • G
                          guzman tierno
                          Thanks so much for your help,
                          I'll try with Windows safe mode on Saturday, 'cause I wont be at work tommorrow.
                          I'll tell you if it does work,
                          thx,
                          guz.
                          • sketch3d.deS
                            sketch3d.de
                            did you have tried runnung SU in Windows safe mode for disabling the SU hardware acceleration option?
                            pluging in a video card is not very diffcult, be grounded before doing this and install (recent) driver w/ admin rights preferred.
                            for pricing check e.g. Amazon, the mentioned ones should not cost more than roughly U$ 100. Don't buy ATI Radeon series... weak OGL support.
                            hth,
                            Norbert
                            • G
                              guzman tierno
                              @sketch3d.de said:
                              run XP in safe mode
                              Here I am,
                              I tried XP in safe mode:
                              by doing so I was actually able to reach sketchup menu bar and turn off hardware accelerations,
                              BUT:
                              when I use Sketchup it only works for 10 secs or so,
                              after that it seems that the options "hardware acceleration" is turned on automatically and
                              SU crashes,
                              restarting it I find the "hardware acceleration" option is turned on.
                              I tried many times, to set the option off, quit the program, etc ...
                              It automatically retruns to ON.
                              I tried SU 6 and SU 7, same result.
                              Any ideas ??
                              (ps: I dont know why, but new files start withount Sang ...)
                              • G
                                guzman tierno
                                In case anyone has the same problem:
                                I finally find the solution (in my situation).
                                The computers I was trying to install SU on,
                                had an Integrated Graphic Processor AND a video card.
                                I finally discovered that by desabling the IGP
                                (from system->hardware->devices->video cards)
                                SU works fine.
                                • G
                                  guzman tierno
                                  I'm really glad that with your help I solved the problem,
                                  THIS wouldnt have been possible otherwise.
                                  Thanks everybody.
                                  guzman.
