    Math functions and SU7
    3 Posts 3 Posters 570 Views 3 Watching
      BillW
      I just noticed while testing some of my SU6 plugins that there is a problem with the inbuilt Ruby Math functions. If I type the following into the Ruby console I get an error:
      tan(20)
      Error: #<NoMethodError: (eval):56: undefined method `tan' for main:Object>
      (eval):56
      Math::tan(20)
      2.23716094422474
      tan(20) works with SU6
      Can someone confirn this
        Jim
        Hi Bill,
        This isn't unexpected behavior. tan is a method of the Math module, and you need to prefix it with the module name in order to call it. If you type in the Ruby Console:
        include Math
        then simply writing tan(20) will work. To ensure you are using Math::tan, and not someone else's 'tan' method, you probably want to always write it as 'Math::tan'
        Here is a chapter which discusses modules as namespaces:
        http://www.rubycentral.com/pickaxe/tut_modules.html
        It could be that there is a plugin in your version 6 folder that uses 'include Math' and so 'tan' is available in your version 6 Ruby Console.
          MarcioAB
          Without "include Math" statement (directly from Ruby's console or from any autoloaded plugin), it does not work here. With "Math included", it works fine.
          Marcio
