    Sketchup game
    3 Posts 2 Posters 592 Views 2 Watching
      Dhruv
      I am building my own code over Prince IO game tht Scott released before few days.
      At the moment I want to do two things
      1. How can I load different .skp files to my game from webdialogue?(I want to do this cause I dont want to go every time to drop down menu from plugins and load the map)
      2. How can I open a web - browser by left clicking on the model? (Something like onclick function from maybe dynamic components)
      Thank you,
      Dhruv Adhia
        Dhruv
        Well I asked him and he told me to post it on forums. I guess he must be busy , he told me that you will have to create your own ruby script and I just started learning ruby.
        • chrisglasierC Offline
          chrisglasier
          Not truly professional I'm sure but this works
          #RUBY
          @dlg.add_action_callback("load") {|d, p|
          	a= p.split(",")
          	subDir ="Components/NamesetComponents/"
          	fileName = a[0]+".skp"
          	model = Sketchup.active_model
          	entities = model.active_entities
          	theX = Integer(a[1]).mm
          	theY= Integer(a[2]).mm
          	theZ = Integer(a[3]).mm
          	point = Geom;;Point3d.new theX,theY,theZ
          	txyz = Geom;;Transformation.new point
                   path = Sketchup.find_support_file fileName, subDir
          	definitions = model.definitions
          	componentdefinition = definitions.load path
          	instance = entities.add_instance componentdefinition, txyz
          	theDegrees = Integer(a[4]).degrees
          	theAxis = a[5]
          	rv = Geom;;Vector3d.new(0,0,1) if theAxis == "z"
          	rv = Geom;;Vector3d.new(0,1,0) if theAxis == "y"
          	rv = Geom;;Vector3d.new(1,0,0) if theAxis == "x"
          	tr = Geom;;Transformation.rotation(Geom;;Point3d.new(instance.bounds.center), rv, theDegrees)
          	instance.transform! tr   }
          //JAVASCRIPT
          function loadSkpFile(){
          param = new Array(theFile,theX,theY,theZ,rz,theAxis)
          param = param.join(",")
          window.location.href = 'skp;load@'+param     }
          @dhruv said:
          1. How can I open a web - browser by left clicking on the model? (Something like onclick function from maybe dynamic components)
          As I understand it, you can do it with a selection observer, but I haven't figured out the code for that.
          Hope this is useful.
          Chris
          With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
