    Review entity count per group/comp?
    3 Posts 3 Posters 513 Views 3 Watching
    • P
      psychomuffin
      Hi all,
      I have a circumstance where I need every group in my model to have exactly 18 entities (12 lines, 6 faces). I have quite a few (hundreds) groups and componants by now that I have to keep track of. I was wondering if there is any way (either natively or ruby) to be able to review these numbers. I'm thinking of something like the outliner where I can see the number of antities. But anything really, as long as I can quickly find anything that does not have the 18 entities I need. My current process is going through each group and checking, which takes quite a while.
      Thanks guys,
      Scott
      • J
        Jim
        Scott,
        Here's a quickie to count the faces and edges. Adds "Check Groups" option the Plugins menu. This assumes the Groups are all top-level in the model and not nested inside other Groups or Components. If it finds an error, it clears the selection, pop-ups a message, and highlights the bad Group. Repeat until you get no pop-ups.
        checkAndSelectGroups.rb
        • chrisglasierC
          chrisglasier
          Quite a different topic but have a look at the bit of code in this post:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14299
          As it walks through the groups and components, I guess you only need to add some code to count the faces and edges of each.
          Outputting to a webdialog would be good so that you could use some javascript to list rogues as links so you can identify and fix them one by one*.
          I would be interested to find out if this approach turns out to be useful.
          Chris
          • edit: or in batches of same problem
          With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
