Attach a material library to an entity
Is it possible to specify a material library for an entity/group/instance?
So instead of going through all entities in an instance and changing their color, you just select another library for that instance.
This to avoid the need to going into all objects of a 350.000 objects model
Register LoginAdvertisement
