    Snap to nearest unit?
    2 Posts 2 Posters 389 Views 2 Watching
    • A
      alz
      I've been searching the script areas, but can't find something that does this --
      Even though I had the length snapping set to 10.00, because the precision was 0.000, I have 100s of objects that are off by .001. For example, 20.34. I want to push all objects to the nearest 10.00 unit. So the previous example would become 20.00.
      Is there a script out there, somewhere, that can snap-to-nearest ?
      TIA,
      alz
      • P
        psychomuffin
        I think what you're looking for is more like a grid snap, like in AutoCAD. SU only has (that I know of) a length snap, so you can start geometry anywhere, but the length is controled at intervals, which doesn't work very well when you want all of your objects to have the same relative snapped distances between each other. I would very much like to see this too.
