    WxWindows for SketchUp Dialogs
    45 Posts 17 Posters 8.3k Views 17 Watching
      Malkomitch
      Have you used the WxFormBuilder? It would be nice to have a straight output compatible with WxSU! There is a beta which works with Python.
      Tomasz
      or you can export your design to a xrc file (xml style) and load it with xml methods from the Wx module.
      xml = Wx::XmlResource.get
      xml.load(your_file.xrc)
      (google for "xrcise", this utility write for you the code needed to load your xrc)
        Malkomitch
        I would appreciate any help with solving this strange bugsplat which appears instead of a simple ruby error message in the console.
        It happens after triggering an 'evt_button'.
        It looks like WxSU doesn't handle errors communication between WxRuby and Sketchup.
        The best way to get rid of bugsplats is to handle exceptions by yourself, at the end of each method that uses WxSU:
        That way, you display the call stack, letting you know where the bug is.
        rescue => detail
           puts detail.message
           puts detail.backtrace.join("\n")
          tomasz
          Thanks a lot for your help.
          I get a bugsplat when closing SU, but it is definitely better this way.
          I though that begin ... rescue ... end is required, but I am glad to hear that rescue alone is sufficient.
          Writing about xml loading I must say that I prefer to write my own Ruby code based on 'initial' FormBuilder layout, as it helps me better understand WxRuby. Thanks for hint anyway!
          Tomasz
          • Dan RathbunD Offline
            Dan Rathbun
            I thought that begin ... rescue ... end is required, but I am glad to hear that rescue alone is sufficient.
            That is because in module definitions, the module statement is a block statement so the word module works the same as begin (after all, the module does need an end.)
            module My_Module
              # method defs
              # code goes here
            rescue
              # error handling code
            else
              # only do code if no exceptions
            ensure
              # always do this code on exit
            end # the end of the method def
            The same is true for method definitions, where the def keyword 'begins' the block.
            def my_method
              # code goes here
            rescue
            else
            ensure
            end # the end of the module
            I'm not here much anymore.
              tomasz
              Thanks for the explanation.
              • 3 / 3
