    Tx rural masterplan
    4 Posts 3 Posters 642 Views 3 Watching
      mirjman
      Two images from a masterplan model for a camp in texas - the site has an amazing deep blue-green river against steep bluffs across from the buildings. Towers on the buildings are being proposed for passive cooling. I'm having trouble with some of the buildings off the the right that seem to be floating over the terrain, especially in the birds-eye view. any suggestions?
      • marked001M Offline
        marked001
        these look pretty good...the overhead shot looks great.. the buildings dont seem to float too much..not noticeable to me... maybe hit your sketchup layers with a slight bit of 'grain' in pshop with the noise or grain filter to just slightly blend them in a bit..but not too much to where you cant tell waht's going on..
        http://www.revision21vis.com
        instagram: revi21on
          ridix
          Nice work.
          As for visual problem, your model shadow on the ground is too light. And the color on the building is simply too bright. So visually it is popping out off the ground. Color blending is needed. If you look at Google Earth, photo image of roof alone contains at least dozen colors! Blending takes some work.
            mirjman
            good comments! I will take another shot at it with some photoshop =D
