    Extended controller support?
    3 Posts 2 Posters 977 Views 2 Watching
    • W Offline
      Wacov
      360 style controllers, with analog triggers, don't work properly, as joyRY is controlled by the triggers, and the right stick doesn't work. I reckon support for the right stick is more important, and maybe the triggers could be put on joyRZ? Something really great would be support for multiple controllers, you could put them on joyLX2 etc.
      Thanks!
        CPhillips
        The problem is every joystick has its own definition about what each stick is called. I need some sort of configuration dialog for joystick. I will do something for SP3.
        • W Offline
          Wacov
          If it helps, it's a saitek rumble P3200. Thanks
