    πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Removing SketchyPhysics 2
    6 Posts 4 Posters 1.8k Views 4 Watching
    • K Offline
      kepler
      Hello,
      I'm just trying to remove SketchyPhysics 2 but I don't know which files I should delete... Can you help me?
        Hi Kepler and welcome to the forums.
        I don't have SP installed on this machine so I cannot answer your question right now but I moved your topic to the SketchyPhysics subforum for more attention.
        Hope these guys can tell you what to do.
        • K Offline
          kepler
          Thank you!
            remus
            There should be a few files in your plugins folder that you need to delete, they are called sketchyphysics.rb and sketchysolids.rb. theres also a folder called sketchyphysics which youll need to delete.
            And from add/remove programs you'll need to get rid of a program called 'sketchyphysics', or something very similar.
            • K Offline
              kepler
              Thank you, I removed the files! πŸ˜‰
                CPhillips
                You can remove the two files and the directory as Remus suggested.
                Or ou can use Add/Remove programs in the control panel to uninstall. Or run the uninstall.exe in plugins\SketchyPhysics\uninstl.
                One unintended side effect of the installer is that it might remove Win32.so from the plugins directory. Some other plugins also require this file. This will be fixed in the next release.
