    Req : arc extend , trim
    7 Posts 3 Posters 1.8k Views 3 Watching
    • majidM Offline
      majid
      hi all , it seems when u draw an arc as the edge of a surface , then it is hard ( or let me say impossible ) to say sketchup , that it is still an arc . so then if u offset it , and then try to extend it to the nearest edge , it is known as a line , and so impossible to extend it. but maybe there is a way!
      my question is : is it possible to have a plugin to extend an arc?
      majid
        remus
        I think the weld plugin should do what you want: http://www.smustard.com/script/Weld
        • majidM Offline
          majid
          ok , thanx Remus , but maybe the image shows what i mean . i need something to extend an arc ( that maybe is an offset of the edge .as shown in picture , i first offset from edge , then need to be extended to edge ..
          • H Offline
            herodes
            Do you want to extend like:
            • retain same number of arc edges? (like a circular stretch?)
            • retain the length of the arc edges (but, increase in number, like copy rotate would do?)
            Both of these can be implemented, it would need either an input dialog to choose which one, or a set of two different [context] menu items.
            %(#BFBFBF)[http://arhitektonas.blogspot.com
            I know me,... I am that guy...
            • majidM Offline
              majid
              yeah ... and also maybe something like what we have in Aytocad as extend ( it can extend an arc or line ...)
              • H Offline
                herodes
                And ofcourse there is no /real/, need for scripting this since it can be done like in this video I have uploaded...
                • majidM Offline
                  majid
                  in my recent projects i faced the same problem again and again : i do an offset over an arc and then i need this arc to be extended .. nad dont know how do i must do this... ( weld , just welds the parts and dont let me to extend - like what there is in autocad ). plz help
