    How to draw complex line ?
    4 Posts 2 Posters 685 Views 2 Watching
    • MALAISEM
      MALAISE
      Hello SU Friends
      I'm facing a little difficulty. I try to follow complex lines (level lines) on a Map, in order to prepare a 3D terrain. Using freehand tool, I can't achieve it, for accuracy reason,in a single step .So I obtain independent segments.
      Question : How to link all theses segments to build a unique "line"
      in order to use the Offset tool ?
      ( of course grouping them isn't the solution, because they stay independent inside the group )
      I mean something like the contrary of "explode". May be a ruby plugin ?
      Thanks for help or advices
      MALAISE 😄
        Maybe this one 😄
        weld.rb
        • MALAISEM
          MALAISE
          That's exactly what I'm looking for! I only believed the plugin was aimed for
          faces.
          Thanks a lot James 👍 👍
          Pilou, you were sending your post in-between
          MALAISE 😄
            There are not exactly the same size, but have the same author Rick Wilson and same N° version 3.0
            Maybe you must take the Smustard link 😉
