    Strange GL draw method behavior
    5 Posts 2 Posters 555 Views 2 Watching
    • Didier BurD Offline
      Didier Bur
      Don't know if it has been discussed before but I have found no response to this question:
      Why view.draw GL_QUADS always draws the quads with a black color ?
      This doesn't work:
      view.drawing_color="red"
      view.draw_line p1,p4
      view.draw GL_QUADS , [p1,p2,p3,p4]
      view.draw GL_QUADS, [p5,p6,p7,p8]
      line is red but quads are black 😞
      Anyone encountered this before ?
      DB
        jhauswirth
        This is just a guess, but polygons need normals to do lighting, so the default normals are probably causing the bad lighting.
        Let's say the normals default to 0,0,0- then that would give you a 0,0,0 for color.
          Didier Bur
          Changing the point's ordering doesn't solve the problem, so it seems not to be a question of normal.
          Same goes with GL_TRIANGLES.
          DB
            jhauswirth
            The real question is how do you specify the normals? You're just giving GL_QUADS the vertices.
              Didier Bur
              Nothing specified in the docs concerning normals. Doc is so sparse you know... πŸ‘Ž I guessed that passing points in a counterclockwise order was orienting the normal up (assuming that these points are on an horizontal plane) ?
              You can notice that once drawn, quads are visible from both sides. Is the normal useless or am I completely wrong ?
              DB
