    Component spray troubleshooting
    2 Posts 2 Posters 395 Views 2 Watching
    • M
      messire
      Hi all,
      I have an issue using spray rb when using the selection option.
      I select a face in a bigger face ( any scale from big ( 100x100m) to small ( 10mx10m) and want the components to be "dropped" on that face. With some settings i get the " u are about to add more than xxxx components are u sure"... with some others ( less spray) i get no message but with both nothing happens.
      The rb works perfectly with other ways of spreading ( circle , path etc etc)
      any hint?
      thnx πŸ˜„
      Nils
      • ToboboT
        Tobobo
        I've been using it loads this last two weeks.
        Firstly if the % is too low then it will struggle to place components the same if the % is too high.
        This just warning saying that it'll take a long time to place the components. I've had to leave the spray running over night. Also it is sometimes better to work in millimetres instead of metres SU copes better.
        Hope I have helped
        Toby
        Philippians 4:13
