    Invitation to the SketchUcation collection
    155 Posts 26 Posters 228.8k Views 26 Watching
      davidheim1
      @chrisjk said:
      David,
      I think my approach would be to wrap a torus round a sphere, intersecting stuff as required to give me the necessary arc lengths, then to cheat a little (or a lot) and use the free training edition of this plugin ( http://www.tgi3d.com/index.php?Page=Download ) to thicken/thin the tube as required to make knuckles. I have not tried to give them any particular shape here - just illustrating the resizing possibilities of the plugin.
      [attachment=1:3dkznoc2]<!-- ia1 -->Knuckles.png<!-- ia1 -->[/attachment:3dkznoc2]
      Other approaches might use Fredo's Tools on Surface to draw the lines for the talons directly on the ball, without cutting up a torus and then use pipe along path or tube along path to create the claws.
      Again, one could employ a method like the one below where I made a radial array of circles (no need for a full circular array of course, then used the MOVE tool on the cardinal points to resize a couple of the circles then used Fredo's Curviloft to skin them.
      [attachment=0:3dkznoc2]<!-- ia0 -->Fredo way.png<!-- ia0 -->[/attachment:3dkznoc2]
      Both are interesting approaches. I'll have to give them a try. What I found, though, is that creating the talons isn't the biggest hurdle: It's blending the talons smoothly in with the thicker part of the leg and creating a convex area, known as the web, between the talons. Quite possibly, it might be simpler to refine the shape of the profile, adding curves for the knuckles, and proceed as I have before. It all depends on how one views the end-purpose of a SketchUp rendering, I think. For me, photorealistic reality isn't the aim; rather, I want to make a drawing that's complete enough to allow someone to build the piece for real. So, the SU version of the ball and claw foot gives the overall size and shape of the element; the final execution depends entirely on the woodcarver's skill, not mine.
      dh
        Good point David. I might add getting two of them to look close enough to the same to be included on the same piece of furniture might be the bigger challenge than carving just one. I could only use ball and claw feet on a piece that is long enough so that you can't see both feet at the same time. 😄
        Nice work on the piece, by the way.
          chrisjk
          David, I quite agree about the end purpose for such a model. I too would not wish to spend a lot of time modelling the feet for the sake of a nicer looking SU model. As I said in my first post, your model is at a stage where it could be used for building the piece.
          Chris
            davidheim1
            Chris (and Dave R):
            Thanks to you both for the compliments and advice. Here's another stab at the foot. Redrew the profile, adding pronounced angles for the knuckles. Then gave the profile thickness, rotated a copy, and used the Split tool in Solid Tools to remove the waste. Extruded the ball and scaled it to fit in the void between the talons. Aggressive softening of the edges at the end. It's better (Solid Tools makes fast work of it), but still not exact. I'll keep at it.
            dh
            ball&claw 1.10.11.skp
              stormking
              My first complex SketchUp designed from scratch and then built...
              http://sketchup.google.com/3dwarehouse/details?mid=1bf8e2a98e2ab4316bdc8a5dbe375ecf
                Pretty nice model, Stormking. I found a few small things that could be changed/cleaned up but overall it's pretty good. Do you have pictures of the actually unit you built? Could you share them?
                  davidheim1
                  A couple of additions:
                  An American Empire-style chair with scroll arms, from "American Furniture Treasures." And a Hepplewhite drawer pull based on a design from Whitechapel Ltd. Both models are also in the 3D warehouse.
                  As always, thanks to Dave Richards for casting his careful eye over the models and finding things that need to be fixed.
                  Also as always, I'd appreciate any kind of feedback.
                  Thanks,
                  David
                  hepplewhite pull.skp
                  empire chair.skp
                    davidheim1
                    Having done some chairs, it was obviously time for me to make a table. You can see it in the 3D warehouse by following this link:
                    Error 404 (Not Found)!!1
                    (sketchup.google.com)
                    The file is too large (5+MB) to post here directly.
                    As always, I'd appreciate feedback of all types.
                    Best,
                    david
                    • K Offline
                      karen05
                      It is very challenging to design or sketch a chair. This will build and enhance our artistic ability. In addition with that, I am very interested to see the American empire chair. I hope you will post it here.
                        davidheim1
                        Dear Karen05,
                        The chair is here. Look up a couple of entries to my post of February 12. You can also find the chair model on the 3D Warehouse by following this link:
                        Let me know what you think of the piece.
                        Thanks,
                        David
                        • F Offline
                          frankwil
                          A gate I made originally designed by a wonderful architect in Santa Fe in the 1930's.
                            Hi Frank,
                            That's a nice looking gate. Very sturdy, too. It is also an excellent illustration of how components can be used to reduce file size. I spent a few minutes fixing your model and reduced the file size by about 83%.
                            Thanks for posting the link to it.
                            • F Offline
                              frankwil
                              Thanks David. I wasn't even thinking along the size line when I submitted it. I went back and did the same thing on the model in the warehouse.
                                The link doesn't work anymore.
                                • P Offline
                                  peterA
                                  Here is a tool cabinet that I drew up for Popular Woodworking magazine. http://sketchup.google.com/3dwarehouse/details?mid=c2ac91973d449b18738e43095496b061&prevstart=0
                                    Hi Peter,
                                    I saw that cabinet the other day. Nice work. Welcome to SCF, too.
                                    • StilTegS Offline
                                      StilTeg
                                      I also have a few like this one below ...
                                      http://sketchup.google.com/3dwarehouse/details?mid=da23d0bdcd1de093de909714df3390c0
                                      Feel free to have a look at my other models ...
                                      doing technical engineering on SketchUp ... without plugins
                                        Very nice. It looks like it would be an interesting piece to build.
                                        If you were interested, you could do some things to improve the efficiency and reduce the file size.
                                        • StilTegS Offline
                                          StilTeg
                                          I am sure of that. This one is a real one we have in our appartment and that my girlfriend spent >1 year to have back to new. It was one of my first "accurate" models, and I have improved my skills in the meantime, but I am not sure I want to dig in it again to improve it 😉
                                            Sometimes it is better to just move on. 😉
                                            • 6
                                            • 7
                                            • 8
                                            • 7 / 8
