Sketchy Physics problem
HI im just getting the hang of sketchy physics 2 and sketch up. I was wondering if it was possible to have it when you hit the play button that the piston joints do not center out or move to the middle position??????
Not with the current version. Although you can usually archive the same results by setting min and max to specific values. What are you trying to do exactly?
You can "fool" the "self centering" action of the piston!
Try to put two identical pistons (Min, max, accel, damp)connected to your oblect.
BUT the pistons must have opposing headings!
i.e. one being drawn downwards, the other upwards.
After this, the control is somewhat more complicate, but no big deal, you can make out
Register LoginAdvertisement
