    Geom point_to_polygon_2D - does it exist
    3 Posts 2 Posters 461 Views 2 Watching
    • B
      BillW
      I thought I would try Geom point_to_polygon_2D
      to test if inside a face outer loop.
      I copied and pasted from the ruby documentation ----- Geom.point_to_polygon_2D
      and got the response on running my ruby
      Error: #<NoMethodError: undefined method `point_to_polygon_2D' for Geom:Module>
      I even tried Geom::point_to_polygon_2D
      I checked the geomtests.rb test file and the test method "pointToPolygon2DTest" was empty
      Does the point_to_polygon_2D method exist under a different name??
      If not, is there any ruby code available anywhere that performs the same check.
      Thanks in advance
      BillW
      • T
        todd burch
        Try point_in_polygon_2D.
        http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-Geom.html#point_in_polygon_2D
        Todd
        (I'll fix the doc)
        • B
          BillW
          Thanks Todd
          I just checked the docs and I should have looked a bit closer rather than doing a straight copy.
          A bit of word blindness going on - my apologies.
