    Silvershadows eye candy 2 : BLACK HAWK
    212 Posts 113 Posters 123.8k Views 113 Watching
      silver_shadow
      our firm is thinking of getting it this week so ill be moving over to su 07 then πŸ˜„
        You could still use the free version until then and simply install the Pro on top later (but of course it's not an urgent "must" to do)
        • boofredlayB Offline
          boofredlay
          Don't rush the man Gai, he has candy to make πŸ˜„
          • G Offline
            gaganraj
            silvershadow,
            on your next presentation could you document an example of how you make one of your more detailed 'pieces?' In your last model you have a few elements that are organic with loads of amazing detail built in and I'm struggling to wrap my brain around it!
            at least a hint?
            thanks! keep up the amazing work and I can't wait to see your newest endeavor.
              silver_shadow
              I will try to be more clearer on how stuff was made in the next candy, of course i will not cover all the elements, some of that will be basic modelling, but i will try to do a couple πŸ˜›
                ceesboersen
                Hi, I am a new member from holland. I tried to introduce myself but that forum wont work at this time. sorry for that. What a great model is this. My question is how do you make the face of the helicopter. I tried it for a long time but with no results. The photos you placed from the building Photos 3 4 and 5 (page 1) these steps are to difficult to understand for me. Please can you give me a short discription of the steps you made to built this.
                Greatings Cees Boersen / Holland
                • artysmediaA Offline
                  artysmedia
                  It seems that i'm late on this post but i mus say this:
                  Y-O-U A-R-E C-R-A-Z-Y S-H-A-D-O-W!!
                  So beautiful, so good! πŸ‘
                  Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                  Blog: Artysmedia
                    silver_shadow
                    hi ceesboersen
                    Making the form of the helicopter was easy with a little bit of trial and error too. First step, i probably should have shown it. I trace the helicopter from the bottom and side. Then i extrude both (bottom and side to meet each other) and then i intersect it with each other. And then just cut off the parts i dont need. I only need half of the model, so i also cut the model in half. Creating ribs is a random thing and yo uput it in as you think it would be useful further up. Once there and you have the ribs, you dont need the rest, so i delete it. Rounding the edges, and then used a tool called skin. This links 2 planes together. So i did that per rib to fill up the model. I know this sounds a little vague, but i will try to explain in my next post.
                    to artysmedia
                    much appreciated and thanks
                      artysmedia
                      Thnaks for the explanation. Maybe i'll try it later, but i dont like a lot making transport units! πŸ’š
                      Blog: Artysmedia
                        ceesboersen
                        Oke thanks for the information. I tried it like that way before and it looks not so nice as yours. Maybe i have to make mor slices to make is soften and smooth. Thanks for the information
                          silver_shadow
                          i know its not as easy and is more of a trial and error and sometimes comes to manually fill spaces to get the look right. Body work of anything do take probably the longest in models like these. Don't give up, you'll get it right πŸ˜›
                            rooster
                            stunning work !! thought i understood SU limits but obviously not. so i have a similar question to above, wouldn't this have been easier to do in Rhino? i am just about to start learning rhino for this reason but maybe i just need to have a good look at SU7.
                              silver_shadow
                              i think any program has its ups and downs in modelling different parts where its maybe easy in one application and hard in the other one. Haven't played with Rhino yet. Mixing platforms is sometimes the best to get good results, the more you know and are able to do..the better. Sketchup is pretty cool still and still try to push it harder and harder. The more practice, the better you get. I think this works for anything in life..if you stop practicing, you rust up and forget. Best solution, find something you like, and stick to that as you main modelling engine.
                              • E Offline
                                erickCMR
                                Phenomenal. Truly phenomenal. Everything about it is impressive but my god man, the level of detail on rotors is what really really impressed me. i just read through the whole thread and there is nothing more to add, everything has been said, except i do have a question: where is Eye Candy 3? And which was Eye Candy 1???
                                • soloS Offline
                                  solo
                                  Without letting the proverbial cat out the bag...Eye candy 3 will happen soon, and brace yourself for it, as it's a whopper. I was able to get a sneak peak during the early phases and that already hurt my jaw as it hit the ground.
                                  Oh! Jacques...no pressure. πŸ’š
                                  http://www.solos-art.com
                                  • StinkieS Offline
                                    Stinkie
                                    Hmm ... Totally looking forward to it. Bring it on! πŸ’š
                                      smokinbakin
                                      Eye Candy Three
                                      "Set your goals low, and hope you don't get lower"
                                      • Chris FullmerC Offline
                                        This is eye candy 1:
                                        http://forums.sketchucation.com/viewtopic.php?f=81&t=10549
                                        Chris
                                        All my Plugins I've written
                                        • olisheaO Offline
                                          olishea
                                          the photoshopped final images are ridiculous. so convincing. hats off, im impressed big time, beautiful πŸ‘ πŸ‘ πŸ‘
                                          oli
                                            silver_shadow
                                            Thank you πŸ˜„
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 9 / 11
