    Silvershadows eye candy 2 : BLACK HAWK
    212 Posts 113 Posters 152.7k Views 113 Watching
    • G
      gaganraj
      silvershadow,
      on your next presentation could you document an example of how you make one of your more detailed 'pieces?' In your last model you have a few elements that are organic with loads of amazing detail built in and I'm struggling to wrap my brain around it!
      at least a hint?
      thanks! keep up the amazing work and I can't wait to see your newest endeavor.
        silver_shadow
        I will try to be more clearer on how stuff was made in the next candy, of course i will not cover all the elements, some of that will be basic modelling, but i will try to do a couple πŸ˜›
        • C
          ceesboersen
          Hi, I am a new member from holland. I tried to introduce myself but that forum wont work at this time. sorry for that. What a great model is this. My question is how do you make the face of the helicopter. I tried it for a long time but with no results. The photos you placed from the building Photos 3 4 and 5 (page 1) these steps are to difficult to understand for me. Please can you give me a short discription of the steps you made to built this.
          Greatings Cees Boersen / Holland
          • artysmediaA
            artysmedia
            It seems that i'm late on this post but i mus say this:
            Y-O-U A-R-E C-R-A-Z-Y S-H-A-D-O-W!!
            So beautiful, so good! πŸ‘
            Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
            Blog: Artysmedia
              silver_shadow
              hi ceesboersen
              Making the form of the helicopter was easy with a little bit of trial and error too. First step, i probably should have shown it. I trace the helicopter from the bottom and side. Then i extrude both (bottom and side to meet each other) and then i intersect it with each other. And then just cut off the parts i dont need. I only need half of the model, so i also cut the model in half. Creating ribs is a random thing and yo uput it in as you think it would be useful further up. Once there and you have the ribs, you dont need the rest, so i delete it. Rounding the edges, and then used a tool called skin. This links 2 planes together. So i did that per rib to fill up the model. I know this sounds a little vague, but i will try to explain in my next post.
              to artysmedia
              much appreciated and thanks
              • artysmediaA
                artysmedia
                Thnaks for the explanation. Maybe i'll try it later, but i dont like a lot making transport units! πŸ’š
                Blog: Artysmedia
                • C
                  ceesboersen
                  Oke thanks for the information. I tried it like that way before and it looks not so nice as yours. Maybe i have to make mor slices to make is soften and smooth. Thanks for the information
                    silver_shadow
                    i know its not as easy and is more of a trial and error and sometimes comes to manually fill spaces to get the look right. Body work of anything do take probably the longest in models like these. Don't give up, you'll get it right πŸ˜›
                      rooster
                      stunning work !! thought i understood SU limits but obviously not. so i have a similar question to above, wouldn't this have been easier to do in Rhino? i am just about to start learning rhino for this reason but maybe i just need to have a good look at SU7.
                        silver_shadow
                        i think any program has its ups and downs in modelling different parts where its maybe easy in one application and hard in the other one. Haven't played with Rhino yet. Mixing platforms is sometimes the best to get good results, the more you know and are able to do..the better. Sketchup is pretty cool still and still try to push it harder and harder. The more practice, the better you get. I think this works for anything in life..if you stop practicing, you rust up and forget. Best solution, find something you like, and stick to that as you main modelling engine.
                        • E
                          erickCMR
                          Phenomenal. Truly phenomenal. Everything about it is impressive but my god man, the level of detail on rotors is what really really impressed me. i just read through the whole thread and there is nothing more to add, everything has been said, except i do have a question: where is Eye Candy 3? And which was Eye Candy 1???
                          • soloS
                            Without letting the proverbial cat out the bag...Eye candy 3 will happen soon, and brace yourself for it, as it's a whopper. I was able to get a sneak peak during the early phases and that already hurt my jaw as it hit the ground.
                            Oh! Jacques...no pressure. πŸ’š
                            • StinkieS
                              Stinkie
                              Hmm ... Totally looking forward to it. Bring it on! πŸ’š
                                smokinbakin
                                Eye Candy Three
                                "Set your goals low, and hope you don't get lower"
                                • Chris FullmerC
                                  This is eye candy 1:
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  • olisheaO
                                    olishea
                                    the photoshopped final images are ridiculous. so convincing. hats off, im impressed big time, beautiful πŸ‘ πŸ‘ πŸ‘
                                    oli
                                      silver_shadow
                                      Thank you πŸ˜„
                                      • olisheaO
                                        olishea
                                        I still cant get over the first photoshopped image, incredible, one of my favourite renders ever! really inspiring stuff
                                        oli
                                          sepo
                                          hehe...eyecandy 3 will be awesome....
                                          • ely862meE
                                            ely862me
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 11
                                            • 9 / 11
