    Get_element_value - not returning anything
    2 Posts 2 Posters 371 Views 2 Watching
      cmprogrock
      Hi all,
      I'm opening a webdialog with a url.
      The page has a span element with ID='TestElement' <span ID="TestElement">Hello World</span>
      I call get_element_value (MyVar = dialog.get_element_value("TestElement")
      I call UI.messagebox MyVar...thinking it will say "Hello World" ... but I get nothing.
      Am I missing something?
      Does get_element_value return a string?
      (I'm sure the page has loaded)
      Any Ideas?
      CM
        Jim
        a SPAN does not have a value. If there is no other HTML in the span, then you can get the contents by innerHTML. I am not sure if using the WebDialog method "get_element_value" will work in this case.
        // javascript
        var txt = document.getElementById("TestElement").innerHTML
