    20 ruby's you can't live without
    22 Posts 19 Posters 5.7k Views 19 Watching
    • N
      nerz
      Well i think we could add to this list the script soapskin i use nearly for each of my projects...
      • FletchF
        Fletch
        1 - make faces
        2 - extrude lines up, extrude lines using 2 points, etc... all them extrude lines commands.
        3 - Windowizer (creates a curtainwall)
        4 - select all instances - is that a ruby, or built-in... I forget now...
        5 - Joint Push Pull (for push-pulling curves)
        6 - pushpull face in any direction (using 2 points), and other pushpull face commands... along normal, along Z, etc.
        7 - stair generator
        8 - SU2KT (SketchUp 2 Kerkythea)
        9 - Proper Animation - (great for showing diff. options for furniture, or doors swinging open)
        10 - Scene Exporter pro - once get used to having it... can't live without.
        11 - Automated 2D Output
        12 - Mirror Selection
        13 - Deselect Edges (Deselect Faces) - I think these are rubies...
        14 - Offset on surface (and tools on surface)
        15 - Purge (this should be number 2)
        16 - Layers and Materials plugin by Didier Bur
        17 - Intersect overlapping lines
        18 - Selection Memory
        19 - Soap Skin Bubble
        20 - Protrude (closest thing we have to greeble plugin for SU)
        Fletch
        3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
        • 2 / 2
