    Simple Rendering
    23 Posts 11 Posters 2.1k Views 11 Watching
      Durant Hapke
      Pot Of Paris,
      Yeah...
      I find this green grass chebba pet deal pleasing as well...
      It kind of makes me want to bathe with it...
      But then there are those scary electric lights... Scary in the sense that I might get a Jack bird spark on me... A burny spark...
      Perhaps I would just like to suckle on it... Suckle on the surface like a needy infant...
      Yeah, that's working.
      Durant "under wire and water" Hapke
      • G Offline
        galbavy1
        @steelers05 said:
        Im actually not quite sure what it is. I just saw it on http://www.archive3d.net/ and decided to render it and try to get better using HDR and Depth of Field with vray. But thanks guys for the feedback.
        hold on hold on.... this is with sketch up? not 3d max? What is HDR and vray if you dont mind me asking.... I though I pushed SU to its limits with the built in stuff. I know there are several "rendering engines" availible but you have to apply the materials in thier programs which seems like a pain in the asss. let me know what is going on here! πŸ‘
          steelers05
          Vray is a rendering plugin used for sketchup. It is similar to the vray plugin for 3d max but a little toned down from what I understand. But you can use SU materials or you can use vray materials...whichever ones you use, you will still need to tweak them cause they need different characteristics to look like what you want. I usually combine the two. Just google vray for sketchup and u will find out a lot more about it. Try checking out podium too...much easier to learn at first.
          • 2 / 2
