    SketchUp Arrays & Enumerable
    7 Posts 3 Posters 1.5k Views 3 Watching
      Jim
      If I type the following in the Ruby Console:
      Array.ancestors
      [Array, Enumerable, Object, Kernel]
      it shows Enumerable is mixed in Array. Is there some reason I can use some methods from Enumerable such as each_with_index, but not each_slice?
      • tbdT Offline
        tbd
        you need to require 'enumerator' to be able to use each_slice
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          Jim
          Why does each_with_index work, while each_slice does not? Both are from Enumerable.
          It seems like only parts of Enumerable are included. Maybe the version of Ruby compiled with SketchUp did not have each_slice at the time.
          • tbdT Offline
            tbd
            if you check the enum.c (Ruby C code for Enumerable class) you will see that only each_with_index is there and each_slice
            is part of ext/enumerator.c 😉
            http://plugins.ro
              Jim
              So here's a list of all the instance methods of an Array in a SketchUp/Ruby array. It has some elements of a regular Ruby Array, some methods of Enumerable, and of course the SketchUp specific methods.
              ["&", "*", "+", "-", "<<", "[]", "[]=", "assoc", "at", "clear", "collect", "collect!", "compact", "compact!", "concat", "cross", "delete", "delete_at", "delete_if", "distance", "distance_to_line", "distance_to_plane", "dot", "each", "each_index", "empty?", "fetch", "fill", "first", "flatten", "flatten!", "index", "indexes", "indices", "insert", "join", "last", "length", "map", "map!", "nitems", "normalize", "normalize!", "offset", "offset!", "on_line?", "on_plane?", "pack", "pop", "project_to_line", "project_to_plane", "push", "rassoc", "reject", "reject!", "replace", "reverse", "reverse!", "reverse_each", "rindex", "select", "shift", "size", "slice", "slice!", "sort", "sort!", "to_ary", "transform", "transform!", "transpose", "uniq", "uniq!", "unshift", "values_at", "vector_to", "x", "x=", "y", "y=", "z", "z=", "zip", "|"]
              I don't think it's complete because I still I missed "each_with_index"
                azuby
                Maybe it depends on the Sketchup version you are using? Mine is 6.4.112 and the result of "puts Array.new.methods.sort" is:
                __id__
                __send__
                all?
                any?
                assoc
                at
                class
                clear
                clone
                collect
                collect!
                compact
                compact!
                concat
                cross
                delete
                delete_at
                delete_if
                detect
                display
                distance
                distance_to_line
                distance_to_plane
                dot
                dup
                each
                each_index
                each_with_index
                empty?
                entries
                eql?
                equal?
                extend
                fetch
                fill
                find
                find_all
                first
                flatten
                flatten!
                freeze
                frozen?
                get_binding
                grep
                hash
                id
                include?
                index
                indexes
                indices
                inject
                insert
                inspect
                instance_eval
                instance_of?
                instance_variable_get
                instance_variable_set
                instance_variables
                is_a?
                join
                kind_of?
                last
                length
                map
                map!
                max
                member?
                method
                methods
                min
                nil?
                nitems
                normalize
                normalize!
                object_id
                offset
                offset!
                on_line?
                on_plane?
                pack
                partition
                pop
                private_methods
                project_to_line
                project_to_plane
                protected_methods
                public_methods
                push
                rassoc
                reject
                reject!
                replace
                respond_to?
                reverse
                reverse!
                reverse_each
                rindex
                select
                send
                shift
                singleton_methods
                size
                slice
                slice!
                sort
                sort!
                sort_by
                taint
                tainted?
                to_a
                to_ary
                to_b
                to_s
                transform
                transform!
                transpose
                type
                uniq
                uniq!
                unshift
                untaint
                values_at
                vector_to
                x
                x=
                y
                y=
                z
                z=
                zip
                  Jim
                  Ah, I used Array.instance_methods but I see that it requires an agument of "true" to get the inherited and mix-in methods also. ( 98 methods )
                  (Array.instance_methods(true) - Object.methods).sort
                  ["&", "*", "+", "-", "<<", "[]", "[]=", "all?", "any?", "assoc", "at", "clear", "collect", "collect!", "compact", "compact!", "concat", "cross", "delete", "delete_at", "delete_if", "detect", "distance", "distance_to_line", "distance_to_plane", "dot", "each", "each_index", "each_with_index", "empty?", "entries", "fetch", "fill", "find", "find_all", "first", "flatten", "flatten!", "grep", "index", "indexes", "indices", "inject", "insert", "join", "last", "length", "map", "map!", "max", "member?", "min", "nitems", "normalize", "normalize!", "offset", "offset!", "on_line?", "on_plane?", "pack", "partition", "pop", "project_to_line", "project_to_plane", "push", "rassoc", "reject", "reject!", "replace", "reverse", "reverse!", "reverse_each", "rindex", "select", "shift", "size", "slice", "slice!", "sort", "sort!", "sort_by", "to_ary", "transform", "transform!", "transpose", "uniq", "uniq!", "unshift", "values_at", "vector_to", "x", "x=", "y", "y=", "z", "z=", "zip", "|"]
