    Visual Lisp
    2 Posts 2 Posters 489 Views 2 Watching
    • P Offline
      pokertiger
      Hi all
      Can you convert DVB visual lisp(autocad add on plugin) to a Ruby language to use in sketch up?
        toxicvoxel
        The data structure in AutoCAD is different to that in Sketchup so code conversion will be quite complicated. Unless the major part of the lisp code in question is computational rather than related to geometry manipulation, you will be better off writing new ruby code from scratch rather than trying to port the code to ruby.
