    First Bathroom render
    3 Posts 3 Posters 586 Views 3 Watching
    • pugz1983P
      pugz1983
      Hi everyone,
      This is my first bathroom render. The mirror needs a some work and I have to fix the lighting. As ussual feedback is welcome
      http://www.freewebs.com/jet3d/badkamer2.jpg
      • marked001M
        marked001
        looks like a good start...really need to do something aobut that wood texture though.... way too small and repetitive...
        http://www.revision21vis.com
        instagram: revi21on
        • R
          Roger
          I recommend cheating the perspective a little bit to make the image more dynamic. I would pull the bamboo plant forward so the leaves are larger in relation to the camera and so they overlap the face of the left hand cabinet a little. Then I would light the leaves so they pop forward from the dark cabinet with a lighter yellow green tone. Don't worry about blocking circulation or access, in the real world you can always move the plant back where it was once you have created the image.
          What I am trying to do is increase the illusion of depth.
          http://www.azcreative.com
