    Problem loading rubies
    5 Posts 3 Posters 802 Views 3 Watching
    • A
      acoffma
      recently hp replaced my broken laptop with a new dv9000 with vista. i have a library of all my scripts that i simply copied over and thought would work fine. all the scripts on my office computer are running with XP and i've had no problem. however when i loaded the scripts to my new computer this is what i get everytime i start up sketchup. i even went back and deleted all the rubies and reinstalled them but it doesnt work. even the layer manager loads up and works fine in sketchup so i dont understand where the error is in that either. any suggestions?
      %(#FF0000)[Error Loading File jointpushpull.rb
      C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2356: syntax error
      menu.add_item(Traductor[DLG_MnuRedo) { JointPushPull.redo }
      C:/Program Files/Google/Google SketchUp 6/Plugins/jointpushpull.rb:2378: syntax errorNo such file to load -- Layer Manager/layer_manager_v6_non_crypte.rbError Loading File layer_manager_extension_v6.rb
      No such file to load -- Layer Manager/layer_manager_v6_non_crypte.rbError Loading File makewindow.rb
      undefined method GetString' for nil:NilClassNo such file to load -- skin.rbError Loading File skin22.rb No such file to load -- skin.rbError Loading File sunangle.rb undefined method GetString' for nil:NilClass]
      • ToboboT
        Tobobo
        Not being an expert but it looks like you need to remove all the scripts named in the errors and then re-download the scripts. The file might have got corrupted through the transfer.
        Toby
        Philippians 4:13
        • A
          acoffma
          have tried it 5 times but still get the same problem. is there a reason they may not work with vista? my personal laptop has vista premium and my office computer has xp and the joint push pull ruby works fine. not too sure what the problem is but i really need to use this script and the problem is annoying. any suggestions?
          • Didier BurD
            Didier Bur
            reading the error, i'd say there is a bug in the menu code:
            Offending line should be:
            menu.add_item(Traductor[DLG_MnuRedo]) { JointPushPull.redo }
            Bracket missing after MnuRedo.
            Maybe you have a buggy version, because Fredo told me that the version at my site is not the latest. Re-download JPP from SCF, re-install. This could be the solution.
            DB
            • A
              acoffma
              ah you are a life saver thank you very much it works great now. i dont understand how the bracket got deleted though. i used the same zip file that i use on my other computer and that one works fine too.
