    Help - Ruby to delete all faces w/o affecting edges?
    5 Posts 5 Posters 833 Views 5 Watching
    • A
      ascook2
      Hi everybody,
      I realize how annoying it can be to answer "noob" questions, but I have been searching for a Ruby Script, and I also didn't find anything in a search of this forum.
      Basically, is there a ruby that can delete all faces, but leave all edges intact? (Simply making it a wire-frame model.) I have an incredibly complex model, and after wasting the last few hours manually deleting faces (pretty desperate, right?), I give up... There must be an easier way.
      None of my faces have any materials applied... I use a plug-in rendering engine to apply all materials. The closest script I could find deleted all faces that had materials applied in SU.
      Although I've been using Sketchup for two years, I've only recently dabbled in ruby scripts.
      I would greatly appreciate any help. Thanks!
      Adam
      • J
        johnsenior1973
        Don't think you need a ruby to do it.
        Just turn off the edges (View-Edge Style-Display Edges), then select all the faces and delete them. Then display the edges again and you should be left with the wireframe only.
        • M
          Matt666
          Hi !
          Your method works only if model is in just one level. But faces can also be inside components or groups (complex entities).
          Here is a script that deletes all faces in the model. πŸ˜‰
          Menu plugins, "delete faces"
          Frenglish at its best !
          My scripts
          • W
            wyatt
            This may be a silly question, but why would you want to delete all the faces? Could you not just turn the model to wireframe mode? I'm curious about the application for such a ruby. Thanks for posting it Matt.
            Wyatt
            • BurkhardB
              Burkhard
              Take a look at Didiers side. There are scripts, deleting edges or faces. I' m not in the office so I can`t take a search for it.
              http://www.ia-plus.de
